Failed applying device templates with status no-namespace/ned-id found
nisheeth
I am trying to implement ADDDC disablement to the cluster cimc.
when tested thru cli it gave the following errors for SMI NED and name space
admin@ncs# show devices list | include ORCMXXXX
ORCMXXXX 10.17.13.13 - cisco-smi-nc-1.2 unlocked
admin@ncs#
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# smi deployment orup0400-aio-1-deployer clusters cluster orup0400-aio-1 device-template apply-rcm-bios-profile-ht-25gbps-no-adddc
admin@ncs(config-device-template-apply-rcm-bios-profile-ht-25gbps-no-adddc)# commit dry-run
Aborted: Python cb_nano_create error. Failed applying device templates to ORCMXXXX with status no-namespace due to: No matching ned-id/namespace found for device: ORCMXXXX.
admin@ncs(config-device-template-apply-rcm-bios-profile-ht-25gbps-no-adddc)# end
Uncommitted changes found, commit them? [yes/no/CANCEL] no
admin@ncs# show running-config devices template apply-rcm-bios-profile-ht-25gbps-no-adddc
ned-id cisco-smi-nc-1.2
config
clusters {$CLUSTER_NAME}
node-defaults host-profile bios-profile-ht-25gbps-no-adddc
node-defaults os tuned enabled true
admin@ncs# show running-config devices template bios-profile-ht-25gbps-no-adddc
config
software host-profile bios-profile-ht-25gbps-add-adddc
url http://10.15.13.17/releases/bios-profile-ht-25gbps-no-adddc.tgz
user #################
password #################
accept-self-signed-certificate true
sha256 ###################################
adm_nsrivas37@ncs# show packages package cisco-smi-* package-version
PACKAGE
NAME VERSION
cisco-smi-deployer 1.5.2
cisco-smi-nc-1.0 1.0
cisco-smi-nc-1.1 1.1
cisco-smi-nc-1.2 1.2
cisco-smi-nc-1.3 1.3
adm_nsrivas37@ncs#
it seems the solution is that i need to refer NED cisco-smi-nc-1.1 into cisco-smi-nc-1.2
Please let me know how to resolve this issue and then i have to automate this process
Nisheeth
0 Replies 0
