For loop in xml template
ksj
I am attempting to use the documented for loop in an xml template and am getting an error that says:
Invalid parameters or processing instruction for
This is the section where I am using the loop:
<interface xmlns="http://tail-f.com/ned/cisco-nx">
<mgmt>
<name>0</name>
<description>{$mgmt_description}</description>
<vrf>
<member>management</member>
</vrf>
<ip>
<address>
<ipaddr>{$mgmt_ip}</ipaddr>
</address>
</ip>
</mgmt>
<Vlan>
<name>1</name>
<shutdown/>
</Vlan>
<?for i=1; {$i < 55}; i={$i + 1}?>
<Ethernet>
<name>1/{$i}</name>
<enable>
<switchport>false</switchport>
</enable>
<description>Auto_Cable_Testing</description>
<ip>
<address>
<ipaddr>192.168.{$cable_test}.{$i*2}/31</ipaddr>
</address>
</ip>
<flowcontrol>
<receive>off</receive>
<send>off</send>
</flowcontrol>
</Ethernet>
<?end?>
</interface>
Any ideas on what I'm doing wrong?
TIA
aelganzo
the for loop is correctly defined, So the questions did you add mgmt_description, mgmt_ip and cable_test variables to your python?
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
