How sync-to works in NSO?
Elvin J
Hi, let’s assume you have a router that you’ve configured in southbound-locked mode. You then send some change requests to NSO, and these changes are stored in the CDB. Later, you switch the mode to unlocked and execute a sync-to. The question is, how will these changes be applied? Will the entire configurations be overwritten, or will only the modified configurations be updated?
snovello
Only the modified configurations are updated.
and you can apply dry-run to check the actual changes that will be sent.
