How to connect to device that requires jump host?
bcaloger
Hey guys !
The title says it all, I'd like to connect to a gate-way that requires a jump-host, any ideas on how to set this up on NSO
Hiro Takahashi
Yes, that is possible. But it might depend on NED though.
Please take a look at following IOS example.
[topology]
NSO ----> (192.168.0.1) jump server ----> (10.0.0.1) IE4000_1 End Device
[Config]
admin@ncs# show running-config devices device Router1
address   192.168.0.1    << IP address of jump server
authgroup IOS
device-type cli ned-id cisco-ios
device-type cli protocol telnet
ned-settings cisco-ios-proxy-settings remote-connection telnet
ned-settings cisco-ios-proxy-settings remote-address 10.0.0.1  << IP address of Router1
ned-settings cisco-ios-proxy-settings remote-port 23
ned-settings cisco-ios-proxy-settings proxy-prompt .*#   << Prompt of jump server
ned-settings cisco-ios-proxy-settings remote-prompt .*#  << Prompt of Router1
ned-settings cisco-ios-proxy-settings remote-name cisco
ned-settings cisco-ios-proxy-settings remote-password cisco
ned-settings cisco-ios-proxy-settings remote-secondary-password cisco
state admin-state unlocked
Best regards,
Hiro
Hiro Takahashi
[topology]
[Config]
authgroup IOS
Best regards,
Hiro
Bruno,
See if this helps:  NED Operation over a Terminal Server
Best,
Scott
sujmurth
Can we have similar settings for
device-type {
    netconf {
        ned-id netconf;
Dont see settings on ned to provide proxy settings
admin@ncs% set devices device CSP1 ned-settings use-
Possible completions:
  use-confirmed-commit  - Control usage of confirmed commit
  use-junos-rollback    - If set to true use device rollback as a revert strategy.
  use-private-candidate - Control usage of the private candidate
  use-startup           - Control usage of the startup datastore
  use-transaction-id    - Control usage of fetching the transaction id
  use-validate          - Control usage of validate
