how to generate XML/CLI capabilities from yang model?
pralala
We need to generate XML capabilities from yang model that can be loaded in NSO using some tool instead of doing a sync-from from a device.
Is there a static way to generate those capabilities/modules?
I tried with pyang. I got the following output
PRALALA-M-27BM:yang pratik$ pyang -f capability viptela-system.yang --capability-entity
http://viptela.com/system?module=viptela-system&revision=2017-05-25&features=
I may have to write some kind of code to extract the URI, revision, modules etc from this string.
I need a solution which is similar to copy-capabalities. But, it is only available to generic or cli based device and not netconf device.
If there is a solution anyone is aware of then please do let me know.
Dan.Sullivan
Hi Pratik,
For netcnonf devices you need to start with a real device and determine the capabilties you will need for you device. Once you understand you can "create" the capabilties fairly quickly. For example consider the following script that copies capabilities from one device to another:
-Dan
def deviceCapabilities(t, src, dst):
      global port
      spath = '/ncs:devices/device{"' + src + '"}'
      dpath = '/ncs:devices/device{"' + dst + '"}'
      cspath = spath + '/capability'
      dspath = dpath + '/capability'
      mspath = spath + '/module'
      mdpath = dpath + '/module'
      with t.cursor(cspath) as caps :
         for cap in caps :
           capability = str(cap[0])
           cp = cspath + '{"' + capability + '"}'
           dp = dspath + '{"' + capability + '"}'
           revision = "none"
           module = "none"
           if (t.exists(cp  + "/revision")) :
               revision = t.get_elem(cp + "/revision");
           if (t.exists(cp + "/module")) :
               module = t.get_elem(cp + "/module");
               msp = mspath + '{"' + str(module) + '"}'
               mdp = mdpath + '{"' + str(module) + '"}'
               if (t.exists(msp)) :
                  if not (t.exists(mdp)) :
                     t.create(mdp)
                  if not (revision == 'none') :
                     t.set_elem(revision, mdp + "/revision")
               if not (t.exists(dp)) :
                 t.create(dp)
                    t.set_elem(revision, dp + "/revision")
                 if not (module == 'none') :
                    t.set_elem(module, dp + "/module")
      return True
Dan.Sullivan
Hi Pratik,
-Dan
      global port
         for cap in caps :
           revision = "none"
           module = "none"
                     t.create(mdp)
                 t.create(dp)
      return True
