05-01-2019 10:59 PM
I am trying to read a csv file from an OS directory and parse its output to nso config. I wanted to implement on the same lines as that of nso in-built command:
admin@ncs(config)# load merge
Possible completions:
<filename> README.ncs devices.xml logs/ ncs-cdb/ ncs.conf netsim/ packages/ scripts/ state/ storedstate target/
When one presses tab in this command, content of ncs-run directory gets listed. I would like to have similar behavior for my service such that when I do: my_service service_name <tab> everything in home directory should get listed.
Shashank Srivastava
05-01-2019 11:48 PM
05-02-2019 03:06 PM
What you need is a completion callback. You can use the extension tailf:cli-completion-actionpoint in your model, and implement a callback to provide the completions. A small snippet is provided in the javadoc for com.tailf.dp.Completion in the NSO documentation. I provide it here for reference:
Having a YANG model snippet like the following:
container application {
leaf file-name {
type string;
tailf:cli-completion-actionpoint "file-complete" {
tailf:cli-completion-id "path";
The corresponding completion action is as follows:
@ActionCallback(callPoint = "file-complete",
callType = ActionCBType.COMPLETION)
public Completion completion(DpActionTrans actx, char cliStyle,
String token, char completionChar,
ConfObject[] kp, String cmdPath,
String cmdParamId, ConfQname simpleType,
String extra) throws DpCallbackException {
// User processing of the completion
CompletionReply reply = Completion.newReply();
reply.addCompletion("completion-entry1", null);
reply.addCompletion("completion-entryN", null);
reply.setCompletionInfo("my-info");
reply.setCompletionDesc("my-description");
return reply;
/Ram
