How to run upgrade class manually for cdb in NSO?
Elvin J
Hello, I have class called  class Upgrade(ncs.upgrade.Upgrade), I enabled this class in package-meta-data.xml. Now I want to run it manually because when I run packages reload it does not run upgrade.py file. Is there any way to run? only way I found is to remove docker container with volumes, but in this case I lose my data in CDB.
Could you please give some hints ?
huayyang
the upgrade component is run by NSO automatically to handle instance data changes according to schema changes(meaning there's a schema change in the package reload), it can't be invoked manually.
why do you want to run it manually?
