03-05-2020 07:41 AM
Hi, I would like to make swagger documentation using yanger. However, I have difficulty figuring out how to do it when my module import other modules.
My yanger command look something like this:
yanger \ --swagger-path-filter=/data/tailf-ncs-services:services/my_service:test \ --format=swagger \ -t expand \ --output=/tmp/test.swagger \ --swagger-host 127.0.0.1:8080 \ test.yang
Since in test.yang I have imported module "test2.yang", I get the following error:
test.yang:13: error: module 'test2' not found
Solved! Go to Solution.
03-05-2020 10:01 AM
Just tested. You can leave off the test2.yang and just specify the directory to the yang folder
so if /var/opt/ncs/packages/TEST/src/yang/test2.yang
it woudl be
-p /var/opt/ncs/packages/TEST/src/yang
03-05-2020 07:59 AM
Add the path for your yang module.
yanger \ --swagger-path-filter=/data/tailf-ncs-services:services/my_service:test \ --format=swagger \ -t expand \ -p /path/to/src/yang/test2.yang --output=/tmp/test.swagger \ --swagger-host 127.0.0.1:8080 \ test.yang
That should load the yang.
03-05-2020 09:09 AM
03-05-2020 10:01 AM
it woudl be
03-05-2020 10:13 AM
Thats works.
Thank you.
