Imported modules in Yanger Swagger
Gastonper
Hi, I would like to make swagger documentation using yanger. However, I have difficulty figuring out how to do it when my module import other modules.
My yanger command look something like this:
yanger \
  --swagger-path-filter=/data/tailf-ncs-services:services/my_service:test \
  --format=swagger \
  -t expand \
  --output=/tmp/test.swagger \
  --swagger-host 127.0.0.1:8080 \
  test.yang
Since in test.yang I have imported module "test2.yang", I get the following error:
test.yang:13: error: module 'test2' not found
Just tested. You can leave off the test2.yang and just specify the directory to the yang folder
so if /var/opt/ncs/packages/TEST/src/yang/test2.yang
it woudl be
-p /var/opt/ncs/packages/TEST/src/yang
tsiemers1
Add the path for your yang module.
yanger \
  --format=swagger \
  -t expand \
 -p /path/to/src/yang/test2.yang
  test.yang
That should load the yang.
Should be an absolute o relative path?
Both yang are in the same package.
I tried :
-p test2.yang
and
-p test/src/yang/test2.yang
But didn't work
it woudl be
Thats works.
Thank you.
