Interface operational state with NSO
RichardD2
We have a need to determine if a particular interface is down (not admin-down, but operationally) with NSO.
It seems trivial to detect admin-state like this, but oddly, oper-status isn't available.
The goal would to use this state in a service template and make logic decisions based on it.
thanks
R
show devices device mydevice live-status interfaces-state interface TenGigE0/0/0/0 admin-status admin-status up
show devices device mydevice live-status interfaces-state interface TenGigE0/0/0/0 oper-status % No entries found.
4 Accepted Solutions
u.avsec
If nothing else works, and if the NED is CLI perhaps do exec
admin@ncs(config)# devices device rtr live-status cisco-ios-xr-stats:exec any "command you want"
The output would have to be parsed though as it will be a string I think.
This two threads do it in python:
https://community.cisco.com/t5/nso-developer-hub-discussions/how-do-i-call-the-devices-device-foo-config-exec-action-from/td-p/3750061
https://community.cisco.com/t5/nso-developer-hub-discussions/execute-show-command-from-nso-action/td-p/3711082
RichardD2
Slight modification to the above, gives us:
admin@nso-lab(config)# devices device mydevice live-status exec any "show interface TenGigE 0/0/0/0" | include line
TenGigE0/0/0/0 is up, line protocol is up
We'll check out the python posts, much appreciated.
hazad
It looks like there might be a mismatch between the device output and what the NED expects. In /cisco-iosxr-cli-7.39/src/gili/if:interfaces-state_interface.gili you see that the NED expects "Line protocol is" with an uppercase L, while the output of the device is "line protocol is" with a lowercase l. You can try to correct it and recompile the NED.
hazad
Awesome! Yes, please go ahead and open a TAC case
8 Replies 8
Nabsch
Hello ,
Which NED are you using ?
can you provide NSO , Ned version ?
Can you execute this command and post the output that you get  .
RichardD2
Thanks for the reply,
Running NSO 5.6.5 with cisco-iosxr-cli-7.38 NED
Result of command above:
 admin-status up
 phys-address d4:6a:35:f4:44:00
 speed        10000000000
 statistics in-octets 35334763881
 statistics in-unicast-pkts 7046572
 statistics in-broadcast-pkts 2
 statistics in-multicast-pkts 4058647
 statistics in-discards 0
 statistics in-errors 1
 statistics in-unknown-protos 0
 statistics out-octets 35249134129
 statistics out-unicast-pkts 6023956
 statistics out-broadcast-pkts 3
 statistics out-multicast-pkts 4050900
 statistics out-discards 0
 statistics out-errors 0
 ipv4 forwarding true
 ipv4 mtu   9180
IP             NETMASK          ORIGIN
1.2.3.4  255.255.255.252  -
 ipv6 forwarding true
 ipv6 mtu   9180
u.avsec
RichardD2
hazad
RichardD2
Thank you, we will give it a go and see what happens.
RichardD2
@hazad - You nailed it, that was exactly the issue. Should I open a TAC case and provide this info, or another approach?
thanks
R
hazad
