1286
jfloresr
ip address allocator allocations not happening sequentially for /31
While working on allocating addresses for point to point links I noticed that allocations for /31s are not happening sequestially. It seems to me like the ip address allocator is skipping the next /31 after allocating first /31 net. For example, I am getting a 172.16.1.0/31 allocation and the next allocation I requested gets a 172.16.1.4/31 instead of 172.16.1.2/31. The same thing happens with any subsequent requests.
Attached is a screenshot for reference as well as other test cases that seem to work fine.
1 ACCEPTED SOLUTION
jvikman
It is by design and you are not the first to question it.
However, if jfloresr has a pressing need for this maybe we should reconsider. Could you describe your scenario more, do you have a workaround?
9 REPLIES 9
jvikman
What version of the resource-manager are you using?
And I assume you would like it to allocate the next /31 subnet?
Can you check if you have two /32 "nets" available (that would make up one /31)?
I am currently using version 3.1.1 from the 4.4.2.1 package.
When I do a show status I see 2 /32s available that makes up the next /31.
We looked at the code and it seems like this was done per design.
jakerby
I believe that would be correct in how it is functioning. NSO probably does not understand the need for a network with network and broadcast ip's only, so it issues a /30
Actually the behavior we saw coded on the allocator is that it will issue the /31 but it will put the other 2 addresses available as /32s.
This is very strange and not conformant with rfc 3021.
Joksan Flores
NETWORK CONSULTING ENGINEER
Cisco Systems
Looking into the code of Resource Manager 4.4.3.2
        if ((!isIpv6 && subs.length == 4 && request == 31 ) ||
            ( isIpv6 && subs.length == 4 && request == 127)) {
             * Split the four into two twos instead
             * Add only single addresses to available.
             * add 3rd and 4th to available.
            availables.add(subs[2]);
            availables.add(subs[3]);
            /* Allocate as a 2-address "Subnet". */
            Allocation a = new Allocation(new Subnet(subs[0].getAddress(), request),
                                          owner, username, requestId);
            allocations.add(a);
            reviewAlarms();
            return a;
It looks as by design it decomposes /30 into /31 which is used and 2 /32
jvikman
We are using resource manager for a POC next month to provision the underlay IPs of an entire fabric as well as the loopbacks. In essence, we take a device with just a management interface configured and provision all the configurations requiring minimal input parameters.
Right now we are requesting the /31 from resource manager and allowing it to waste the 2 /32s. Unfortunately the pools for Infrastructure IPs and loopbacks is different so all the /32s are wasted currently.
Joksan Flores
ENGINEER.NETWORK CONSULTING
Cisco Services
jfloresr@cisco.com<mailto:jfloresr@cisco.com>
Tel: +1 919 392 2635
Mobile: +1 919 710 2045
houlee
We have a customer challenging us exactly the same issue too. They are not happy about the extra two unused IPs. Is this considered as a bug or how we communicate back to the customer about this feature/design?
Thanks.
This is considered a feature, since it is on purpose - though people seem to largely agree that it is not a good feature.
There are tickets on this, but there is no timeline for when this will be adressed. For customers, work through the ticket system to reach resolution.
