Is it possible to pick up changes to cb_create() without reloading packages?
tcragg1
Is there a way to make NSO pick up changes made in the cb_create() method for a python service package without having to do a "packages reload"? A "python-vm stop name <<package-name>>" does not seem to trigger the changes being picked up.
gmuloche
if you have changes only to the code like you describe you can use
packages package <package-name> redeploy
And it will work. Please note that it does not work for YANG model changes (need to recompile and packages reload) nor for change in XML templates (packages reload needed as well).
gmuloche
