is there a NED for working with Nokia BNGs ?
Ahmed Elsamahy
i am working on a service over Nokia BNGs and i cannot find a Nokia NED . is it not supported ?
If the Nokia/ALU BNG runs the Nokia SR OS then the alu-sr NED is the one to use. As usual, if there is a gap in the commands supported by the NED then you issue a request as per the process posted here on the NSO Developer Hub
6 Replies 6
joepak
There is nokia-nsp/alu-sr NEDs.
Not sure if they work with BNGs.
i will check and send you results
i found alu NED but i cannot find nokia nsp or alu NED can work with Nokia too?
I think the alu-sr NED covers quite a few devices. I can't personally test since we don't have Nokia devices readily available.
Hi Ahmed,
We do have a "POC status" Nokia NSP NED that we are testing mainly for optical configuration. Please contact your Cisco sales contact to check if your usecase matches the POC NED.
Roque
