Everyone,
Do you know if the NED for Cisco AireOS is capable of managing the Cisco Mobility Express Wireless Controller (WLC) module that can be loaded into an AireOS AP.
The current version for Cisco Mobility Express is 8.7, https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/87/user_guide/b_ME_User_Guide_87/getg_started.html
Yes, the current Aireos NED supports WLC module.
Fredric
Frederic, can you please point me where to get the package. I downloaded cisco-aireos-3.3.2 from "earth.tail-f.com" and looking at the model I did not find the mappings to several commands such as:
For example, I only see config 802.11h channelswich :
container "eight02.11h" {
tailf:ncs-device-type "cli-ned";
tailf:display-when "not(../../ncs:module) or ../../ncs:module[ncs:name='tailf-ned-cisco-aireos']";
tailf:info
"Configures 802.11h parameters.";
tailf:alt-name "802.11h";
tailf:cli-compact-syntax;
container channelswitch {
tailf:info
"Configures the 802.11h channel switch announcement.";
tailf:meta-data "handle-802.11a-disable";
tailf:ned-data "/eight02.11a/enable-disable" {
tailf:xpath-root 3;
tailf:transaction from;
choice enable-disable {
container enable {
tailf:info
"Enables the 802.11h channel switch announcement.";
leaf enable-type {
tailf:cli-drop-node-name;
type enumeration {
enum "loud" {
tailf:info
"Enables the 802.11h channel switch announcement in the loud
mode. The 802.11h-enabled clients can send packets while
switching channel.";
enum "quiet" {
tailf:info
"Enables 802.11h-enabled clients to stop transmitting packets
immediately because the AP has detected radar and client devices
should also quit transmitting to reduce interference.";
leaf disable {
tailf:info
"Disables the 802.11h channel switch announcement.";
type empty;
Here the CLI reference guide for CME 8.7
