07-29-2019 02:19 PM
I am trying out the new load-native-config command under NSO 5.1.1. When I try it, I get errors like this:
admin@ncs(config)# devices device ios0 load-native-config data "hostname asd" Error: External error in the NED implementation for device ios0: not implemented admin@ncs(config)# devices device dell0 load-native-config file test.ftos mode replace verbose Error: External error in the NED implementation for device dell0: not implemented
ios0 and dell0 are both netsims. ios0 was created with the sample cisco-ios-cli-3.8 NED that came with NSO 5.1.1. dell0 was created with the new Dell FTOS NED.
What am I doing wrong?
-Allen
Solved! Go to Solution.
07-30-2019 05:28 AM
Hello the NED that comes as example are quite old - if you look at the CHANGES.txt for cisco-ios-cli-3.8
1 cisco-ios v3.8.0 [March 16, 2015] 2 ================================= 3 4 Enhancements: 5 6 - Support for NCS-3.4.
The support for cisco-ios NED for load-native config was added later:
393 cisco-ios v6.20.3 [2019-04-05] 394 ============================== 402 403 - Added support for NSO 5.1 config CLI command 'load-native-config' which 404 can be used to load and convert device config into ncs_cli config mode: 405 admin@ncs(config)# devices device <device> load-native-config data|file 406 Note: Even with netsim the data is parsed as it was in native IOS format. 407 (CISCOIOS-1360)
I assume it is the same explanation for the Dell NED.
07-30-2019 05:28 AM
07-30-2019 07:15 AM
Thanks for the reply. I didn't know that additional work had to be done to add support for load-native-config. The Dell NED is brand new, but they probably didn't add support for it, either. I'll open a TAC case to request it.
-Allen
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
