NACM rule per-leaf content
previousqna
Level 5
Level 5
Hi experts,
Suppose that we have an enumeration-type leaf which has 4 possible values: val1, val2, val3, val4.
Is it possible to create a NACM rule that will allow some groups (say, grp1, grp2, grp3) to set the leaf to val1, val2, val3, but will allow only grp1 to set the leaf value to val4?
If so, how?
If not, can you think of an alternative to NACM to allow this behavior?
previousqna
Level 5
Level 5
I believe your request is more of a policy rather than a NACM rule. Unfortunately, a policy applies to all users.
A possible solution is to perform stacked services where you have two services that set the value:
  • Service1 runs to set the values to val1, val2 and val3, while Service 2 set the value to val4.
  • The top service applies either Service1 or Service2, depending on the value to be set.
  • NACM rules governs the creation of Service1 and Service2 to the correct groups.
Thank you for the suggestion!
I should mention that I have had many discussions with engineering to see how we could create more advance NACM rules that include so sort of policy in them (or conversely a user-aware policy).
The problem we face is performance. We have not found the way to create them without affecting the performance of the platform.
