09-25-2023 02:05 AM - edited 09-25-2023 07:43 PM
We are evaluating NSO version UP from 4.7.1 to 5.7.10.1
An Action point worked in 4.7.1 is not working after upgrade to 5.7.10.1 as below:
<INFO> 13-Sep-2023::15:42:08.570 foo ncs-dp-385541-foo:main:0-4-usid-216-foo-show-alarms: - Action called (service=/foo:action)
<INFO> 13-Sep-2023::15:42:08.570 foo ncs-dp-385541-foo:main:0-4-usid-216-foo-show-alarms: - Action name: show-alarms
<INFO> 13-Sep-2023::15:42:08.570 foo ncs-dp-385541-foo:main:0-4-usid-216-foo-show-alarms: - Action input.device: bar
<ERROR> 13-Sep-2023::15:42:09.863 foo ncs-dp-385541-foo:main:0-4-usid-216-foo-show-alarms: - Missing key argument in create
<ERROR> 13-Sep-2023::15:42:09.865 foo ncs-dp-385541-foo:main:0-4-usid-216-foo-show-alarms: - Traceback (most recent call last):
File "/opt/ncs/ncs-5.7.10.1/src/ncs/pyapi/ncs/dp.py", line 665, in wrapper
ret = fn(self, uinfo, str(name), kp, input, output, act_trans)
File "/opt/ncs/ncs-5.7.10.1/src/ncs/pyapi/ncs/dp.py", line 626, in fn2
return ofn(self, uinfo, name, kp, input, output)
File "/var/opt/ncs/state/packages-in-use/1/foo/python/foo/action_show_alarms.py", line 30, in cb_action
alarms_device.validate(output, self.log)
File "/var/opt/ncs/state/packages-in-use/1/foo/python/foo/action_show_alarms.py", line 52, in validate
if not alarm.validate(maagic_node.alarms.create()):
File "/opt/ncs/ncs-5.7.10.1/src/ncs/pyapi/ncs/maagic.py", line 1236, in create
raise MaagicError("Missing key argument in create")
ncs.maagic.MaagicError: Missing key argument in create
It looks like related to ENG-18102
Using Maagic to create a keyed list entry in an input or output section of an action now need the key(s) to be specified in the create() call. [ENG-18102/python-api non-backwards compatible correction]
However, we have no idea whether this error came from this ENG and how we can fix it.
Does anyone hove information?
09-28-2023 03:16 PM - edited 09-28-2023 03:17 PM
You are calling create function with no arg , you need to pass an arg otherwise it won't work.
Here an example
----> 1 root.devices.device.create()
File ~/ncs-5.8.10/src/ncs/pyapi/ncs/maagic.py:1295, in List.create(self, *keys)
1293 keys = maapi.Key(len(self))
1294 elif len(keys) == 0:
-> 1295 raise MaagicError("Missing key argument in create")
1296 elif len(keys) == 1:
1297 keys = maapi.Key(keys[0])
In [14]: root.devices.device.create("test")
Out[14]: ListElement name=device tag=617911018 keys={test}
10-04-2023 08:19 AM
Is "maagic_node.alarms" representing a list node(with key) in the model? If so, ENG-18102 introduced a non-backwards-compatible change from 5.1 which prohibits list(with key) creation without a key, and the fix is either passing a key to create() call or changing the model to use a keyless list.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
