08-28-2017 02:41 PM - edited 03-01-2019 03:58 AM
If I've downloaded a NED which has been compiled for NSO x.y.z, will it work with NSO x.y.z.a? I ask because I don't see a NED compiled specifically for NSO x.y.z.a.
Michael Bonnett, Jr.
Solved! Go to Solution.
08-29-2017 01:02 AM
Yes, it should according to our compatibility rules. There's always the risk of any change introducing a bug, and the combination may be yet untested, but I would say you should have a very high degree of confidence when a fourth digit is added or changes.
08-29-2017 01:02 AM
08-29-2017 05:40 AM
Jan,
I assumed that was the case. Thanks for the confirmation.
Michael
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
