michaelbonnettjr
NED and NSO release compatibility
If I've downloaded a NED which has been compiled for NSO x.y.z, will it work with NSO x.y.z.a?  I ask because I don't see a NED compiled specifically for NSO x.y.z.a.
Michael Bonnett, Jr.
1 ACCEPTED SOLUTION
Jan Lindblad
Yes, it should according to our compatibility rules. There's always the risk of any change introducing a bug, and the combination may be yet untested, but I would say you should have a very high degree of confidence when a fourth digit is added or changes.
2 REPLIES 2
Jan Lindblad
Jan,
I assumed that was the case. Thanks for the confirmation.
Michael
