need a working exmple how to set up a VM/VNF on vmware using ESC
Zoltan Kinczli
hey,
  i'm trying to set up a VM/VNF on VMware usign ESC
  i have ESC up on a VM, in sync w/ NSO
  trying to configure vm_group, but getting "operation_failed: undefined"  - not too informative
  a working example would be a lifesaver
thanks, cheers
  --z.
Zoltan Kinczli
finally i have a VNF deployed, so i can answer my own question:
couple of gotha:
  - no tenants on vcenter - everything is under the default (admin) tenant
  - on vcenter datastore a folder called esc-ovas has to be created
  - OVA file may have to be edited
     remove serial console, CD-rom
     align network names in OVF ?manifest?
  - image under deployment/vm_group must have esc-ova specified as path
  - volume under deployent/vm_group must refer to volume defined under admin tenant
     yet, i had to define some size (with sizeunit) unde deployment/vm_group - no clue why
this just got me a VNF deployed and powered on
admin@ncs# show running-config devices device esc-aslab config | display xml
<config xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
  <device>
    <name>esc-aslab</name>
      <config>
        <esc_datamodel xmlns="http://www.cisco.com/esc/esc">
          <tenants>
            <tenant>
              <name>admin</name>
              <description>Built-in Admin Tenant</description>
              <managed_resource>false</managed_resource>
              <vim_mapping>true</vim_mapping>
              <volumes>                                                  <==== refer to datastore on vcenter
                <volume>
                  <name>LocalDisk600GB</name>
                  <size>600</size>
                  <sizeunit>GiB</sizeunit>
                  <type>local</type>
                </volume>
                <volume>
                  <name>Netapp_4TB</name>
                  <size>4</size>
                  <sizeunit>TiB</sizeunit>
                  <type>network</type>
                </volume>
              </volumes>
              <deployments>
                <deployment>
                  <name>VPAGENT-VNI3000-ESC-ASLAB</name>
                  <locators>
                    <datacenter>aslab</datacenter>                              <==== VDC name in vcenter
                    <switch_name>dvSwitch-ESC</switch_name>        <==== must create a distributed switch in vcenter
                  </locators>
                  <vm_group>
                    <name>VPAGENT-VNI3000-ESC-ASLAB-VM</name>
                    <image>esc-ovas/vPag1</image>                             <==== esc-ovas folder must exist
                    <bootup_time>300</bootup_time>
                    <recovery_wait_time>120</recovery_wait_time>
                    <volumes>
                      <volume>
                        <volid>1</volid>
                        <size>5</size>
                      </volume>
                    </volumes>
                    <interfaces>
                      <interface>
                        <nicid>1</nicid>
                        <type>virtual</type>
                        <network>ESC-MGMT</network>                              <==== portgroup under distributed switch
                        <ip_address>192.168.0.1</ip_address>
                      </interface>
                      <interface>
                        <nicid>2</nicid>
                        <network>ESC-VM</network>                                    <==== portgroup under distributed switch
                        <ip_address>192.168.1.1</ip_address>
                      </interface>
                    </interfaces>
                    <kpi_data>
                      <enabled>true</enabled>
                      <kpi>
                        <event_name>VM_ALIVE</event_name>
                        <metric_value>1</metric_value>
                        <metric_cond>GT</metric_cond>
                        <metric_type>UINT32</metric_type>
                        <metric_collector>
                          <type>ICMPPing</type>
                          <nicid>1</nicid>
                          <poll_frequency>5</poll_frequency>
                          <polling_unit>seconds</polling_unit>
                          <continuous_alarm>false</continuous_alarm>
                        </metric_collector>
                      </kpi>
                    </kpi_data>
                    <rules>
                      <admin_rules>
                        <rule>
                          <action>ALWAYS log</action>
                        </rule>
                      </admin_rules>
                    </rules>
                    <config_data>
                      <configuration>
                        <dst>day0-config</dst>
                        <file>http://host/path/vpagent-VNI3000-day0-confg.txt</file>
                        <variable>
                          <name>HOSTNAME</name>
                          <val>VPAGENT-VNI3000-ESC-ASLAB</val>
                        </variable>
                      </configuration>
                    </config_data>
                    <scaling>
                      <min_active>1</min_active>
                      <max_active>1</max_active>
                      <elastic>true</elastic>
                    </scaling>
                    <placement>
                      <type>zone_host</type>
                      <zone>infra</zone>
                    </placement>
                  </vm_group>
                </deployment>
              </deployments>
            </tenant>
          </tenants>
          <images>
            <image>
              <name>vPag1</name>
              <src>file://tmp/vPag1.ova</src>
              <size>52</size>
              <sizeunit>MiB</sizeunit>
              <disk_format>vmdk</disk_format>
              <container_format>ova</container_format>
              <serial_console>false</serial_console>
              <disk_bus>virtio</disk_bus>
              <visibility>public</visibility>
              <locators>
              </locators>
            </image>
          </images>
        </esc_datamodel>
        <esc_system_config xmlns="http://www.cisco.com/esc/esc">
          <vim_connectors>
            <default_vim_connector>default_vmware_vim</default_vim_connector>
            <vim_connector>
              <id>default_vmware_vim</id>
              <type>VMWARE_VSPHERE</type>
              <properties>
                <property>
                  <name>vcenter_ip</name>
                  <value>10.10.10.10</value>
                </property>
                <property>
                  <name>vcenter_port</name>
                  <value>80</value>
                </property>
              </properties>
              <users>
                <user>
                  <id>user-name</id>
                  <credentials>
                    <properties>
                      <property>
                        <name>vcenter_password</name>
                        <value>password</value>
                      </property>
                    </properties>
                  </credentials>
                </user>
              </users>
            </vim_connector>
          </vim_connectors>
        </esc_system_config>
      </config>
  </device>
  </devices>
</config>
admin@ncs#
Zoltan Kinczli
couple of gotha:
  <device>
      <config>
          <tenants>
            <tenant>
              <name>admin</name>
                <volume>
                  <size>600</size>
                  <type>local</type>
                </volume>
                <volume>
                  <size>4</size>
                </volume>
              </volumes>
              <deployments>
                <deployment>
                  <locators>
                  </locators>
                  <vm_group>
                    <volumes>
                      <volume>
                        <volid>1</volid>
                        <size>5</size>
                      </volume>
                    </volumes>
                    <interfaces>
                      <interface>
                        <nicid>1</nicid>
                      </interface>
                      <interface>
                        <nicid>2</nicid>
                      </interface>
                    </interfaces>
                    <kpi_data>
                      <kpi>
                        <metric_collector>
                          <nicid>1</nicid>
                        </metric_collector>
                      </kpi>
                    </kpi_data>
                    <rules>
                      <admin_rules>
                        <rule>
                        </rule>
                      </admin_rules>
                    </rules>
                    <config_data>
                      <configuration>
                        <variable>
                        </variable>
                      </configuration>
                    </config_data>
                    <scaling>
                    </scaling>
                    <placement>
                      <zone>infra</zone>
                    </placement>
                  </vm_group>
                </deployment>
              </deployments>
            </tenant>
          </tenants>
          <images>
            <image>
              <name>vPag1</name>
              <size>52</size>
              <locators>
              </locators>
            </image>
          </images>
        </esc_datamodel>
          <vim_connectors>
            <vim_connector>
              <properties>
                <property>
                </property>
                <property>
                  <value>80</value>
                </property>
              </properties>
              <users>
                <user>
                  <id>user-name</id>
                  <credentials>
                    <properties>
                      <property>
                      </property>
                    </properties>
                  </credentials>
                </user>
              </users>
            </vim_connector>
          </vim_connectors>
      </config>
  </device>
  </devices>
</config>
admin@ncs#
