netconf device sync fromm get Protocol error
sm000x
I have a strange issue and I cannot figure out what was wrong.
I have a netconf device but when I do sync-from I got error:
admin@ncs> request devices device zrdm60gcsmf01 sync-from
result false
info Failed to connect to device zrdm60gcsmf01: Protocol error
[ok][2024-02-18 13:33:20]
admin@ncs> exit
and the trace log size is 0:
-rw-rw-r--. 1 sm000x sm000x 0 Feb 18 13:33 netconf-zrdm60gcsmf01.trace
However, I am able to use
ssh -s sm000x@zrdm60gcsmf01-ip-addess -p 22 netconf
to invoke the netconf (Although it takes longer than usual time)
The device type is netconf:
admin@ncs> show configuration devices device zrdm60gcsmf01
address x.x.x.x;
port 22;
authgroup SMF;
device-type {
netconf {
ned-id smf-nc-1.0;
state {
admin-state unlocked;
I am able to do sync-from to other device with the same authgroup and ned-id:
dmin@ncs> request devices device z68bcsmf01 sync-from
result true
[ok][2024-02-18 13:49:42]
admin@ncs> show configuration devices device z68bcsmf01
address x.x.x.x;
port 22;
authgroup SMF;
device-type {
netconf {
ned-id smf-nc-1.0;
state {
Does anyone have same expierence?
What does "Protocol error" mean?
THX
sm000x
25 Replies 25
Hi, cohult:
Thank you so very much for your input.
I will contact the device manager to investigate your suggestion.
THX
sm000x
cohult
Hi @sm000x,
As an example, the device manager (vendor A) can, for their OpenSSH server, separate the NETCONF port from the CLI port, with NETCONF on its IANA assigned port 830. Example device /etc/ssh/sshd_config:
Port 22
Port 830
Match LocalPort 830
    PasswordAuthentication yes
    AuthenticationMethods publickey password
    ForceCommand /path/to/bin/netconf-subsys
Match all
PasswordAuthentication no
AuthenticationMethods publickey keyboard-interactive
ForceCommand /path/to/bin/confd_cli
Subsystem	netconf    /path/to/bin/netconf-subsys
Another option is to run two sshd instances serving either the CLI or NETCONF on separate ports.
Hi, cohult:
Thank you so much for this information. I will forward to the device vendor and the device manager.
Thank you
sm000x
If the keyboard-interactive authentication type is enabled for the device SSH server, try disabling it.
sm000x: I do not know how to check and how do disable it.
Here is the -vv ssh:
[root@mtnjdslncs06 ~]# ssh -vv sm000x@166.193.252.44
OpenSSH_7.4p1, OpenSSL 1.0.2k-fips 26 Jan 2017
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 58: Applying options for *
debug2: resolving "166.193.252.44" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 166.193.252.44 [166.193.252.44] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: key_load_public: No such file or directory
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: identity file /root/.ssh/id_dsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa type -1
debug1: identity file /root/.ssh/id_ecdsa-cert type -1
debug1: identity file /root/.ssh/id_ed25519 type -1
debug1: identity file /root/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.8
debug1: match: OpenSSH_8.8 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 166.193.252.44:22 as 'sm000x'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa,ssh-dss
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256@libssh.org,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-ed25519,ecdsa-sha2-nistp256,ssh-rsa
debug2: ciphers ctos: aes256-ctr,aes192-ctr,aes128-ctr
debug2: ciphers stoc: aes256-ctr,aes192-ctr,aes128-ctr
debug2: MACs ctos: hmac-sha2-512,hmac-sha2-256
debug2: MACs stoc: hmac-sha2-512,hmac-sha2-256
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: aes128-ctr MAC: hmac-sha2-256 compression: none
debug1: kex: client->server cipher: aes128-ctr MAC: hmac-sha2-256 compression: none
debug1: kex: curve25519-sha256@libssh.org need=32 dh_need=32
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:yv7ZAEJqIeK6M/iDvyJrRLhsa7JXTKN4THFkWISsbWI
The authenticity of host '166.193.252.44 (166.193.252.44)' can't be established.
ECDSA key fingerprint is SHA256:yv7ZAEJqIeK6M/iDvyJrRLhsa7JXTKN4THFkWISsbWI.
ECDSA key fingerprint is MD5:97:96:a6:de:eb:bc:c5:8f:cc:ea:d9:fb:c3:ca:97:98.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '166.193.252.44' (ECDSA) to the list of known hosts.
debug2: set_newkeys: mode 1
debug1: rekey after 4294967296 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /root/.ssh/id_rsa ((nil))
debug2: key: /root/.ssh/id_dsa ((nil))
debug2: key: /root/.ssh/id_ecdsa ((nil))
debug2: key: /root/.ssh/id_ed25519 ((nil))
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /root/.ssh/id_rsa
debug1: Trying private key: /root/.ssh/id_dsa
debug1: Trying private key: /root/.ssh/id_ecdsa
debug1: Trying private key: /root/.ssh/id_ed25519
debug2: we did not send a packet, disable method
debug1: Next authentication method: password
sm000x@166.193.252.44's password:
Thx
sm000x
Nabsch
Regarding the trace, maybe you need to enable them.
devices device <device_name> trace raw
commit dry-run
commit
devices device <device_name> connect
Can you also execute the following  command and post the output
devices device <device_name> connect | detail debug
#sync-from but if it's fails for the connect it will also  fail for the sync-from
devices device <device_name> sync-from | detail debug
Regarding the other devices  , are they using the same version ? Same config ssh/netconf config ?
Hi, Nabsch:
admin@ncs% set devices device zrdm60gcsmf01 trace raw
[ok][2024-02-20 17:54:32]
[edit]
admin@ncs% commit dry-run
cli {
local-node {
data devices {
device zrdm60gcsmf01 {
- trace pretty;
+ trace raw;
[ok][2024-02-20 17:54:38]
[edit]
admin@ncs% commit
Commit complete.
[ok][2024-02-20 17:54:50]
[edit]
admin@ncs% request devices device zrdm60gcsmf01 connect
result false
[ok][2024-02-20 17:55:19]
[edit]
admin@ncs%
[sm000x@mtnjdslncs06 logs]$ ls -l *zrdm60gcsmf01*
THX
sm000x
Hi, Nabsch:
admin@ncs> request devices device zrdm60gcsmf01 connect | details debug
2024-02-20T18:01:08.448 device zrdm60gcsmf01: connect...
2024-02-20T18:01:08.448 device zrdm60gcsmf01: SSH connecting to admin@zrdm60gcsmf01
2024-02-20T18:01:15.046 device zrdm60gcsmf01: connect: error (6.598 s)
result false
[ok][2024-02-20 18:01:15]
address x.x.x.x;
port 22;
authgroup SMF;
device-type {
netconf {
ned-id smf-nc-1.0;
trace raw;
state {
[ok][2024-02-20 18:02:19]
admin@ncs> show configuration devices authgroups group SMF
umap admin {
remote-name sm000x;
remote-password $9$n1M6TW3Rwz6ZBB9BsLs3zBDo43EO8QJS2QQ2vLdxzTo=;
[ok][2024-02-20 18:02:31]
admin@ncs>
For other device with same auth group:
address y.y.y.y;
port 22;
authgroup SMF;
device-type {
netconf {
ned-id smf-nc-1.0;
state {
admin@ncs> request devices device z68bcsmf01 connect | details debug
2024-02-20T18:07:53.924 device z68bcsmf01: connect...
2024-02-20T18:07:53.924 device z68bcsmf01: SSH connecting to admin@z68bcsmf01
2024-02-20T18:07:55.465 device z68bcsmf01: reuse SSH connection to admin@z68bcsmf01
2024-02-20T18:07:56.502 device z68bcsmf01: connect: ok (2.578 s)
result true
info (admin) Connected to z68bcsmf01 - y.y.y.y
[ok][2024-02-20 18:07:56]
THX
sm000x
Nabsch
Regarding the other devices  , are they using the same version ( device os version) ? Same config ssh/netconf config ( i mean device config) ?
Hi, Nabsch:
sm000x: No, the other device is older OS version. The device in question is the newer version. Therefore, ssh/netconf might or might not be the same.
THX
sm000x
Nabsch
Can you switch to netconf ned & check if the connect is working ? ( IF you have no services on it otherwise create a new device that use the previous ip
devices device <device-name> device-type netconf ned-id netconf
Hi, Nabsch:
admin@ncs% set devices device zrdm60gcsmf01 device-type netconf ned-id netconf
[ok][2024-02-21 08:41:14]
[edit]
admin@ncs% commit
Commit complete.
[ok][2024-02-21 08:41:17]
[edit]
admin@ncs% exit
[ok][2024-02-21 08:41:20]
admin@ncs> request devices device zrdm60gcsmf01 ssh fetch-host-keys
result unchanged
fingerprint {
algorithm ssh-ed25519
value 77:a5:d4:e5:d0:1c:ca:18:d4:e0:36:f4:d6:7b:b0:b1
fingerprint {
algorithm ecdsa-256
value a0:a9:c8:4c:37:37:de:a5:5d:fa:0a:ca:f7:70:71:df
fingerprint {
algorithm ssh-rsa
value 1f:bb:4a:95:93:9e:aa:46:f3:44:d4:6c:d1:ac:65:1d
[ok][2024-02-21 08:41:33]
2024-02-21T08:41:46.288 device zrdm60gcsmf01: connect...
2024-02-21T08:41:46.288 device zrdm60gcsmf01: SSH connecting to admin@zrdm60gcsmf01
2024-02-21T08:41:52.837 device zrdm60gcsmf01: connect: error (6.548 s)
result false
[ok][2024-02-21 08:41:52]
admin@ncs>
THX
sm000x
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
