Highlighted
netconf ned for xr662
I tried to build xr662 netconf ned by nso5.2.x native netconf ned builder tools, as follow:
admin@ncs# netconf-ned-builder project xr 6.6 fetch-module-list
admin@ncs# netconf-ned-builder project xr 6.6 module Cisco-IOS-XR-* * select
admin@ncs# netconf-ned-builder project xr 6.6 build-ned
admin@ncs# show netconf-ned-builder project xr 6.6 build-status
build-status success
But when update netconf id in device, then sync-from, found follow alarm:
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# devices device xrv9k-controller
admin@ncs(config-device-xrv9k-controller)# device-type netconf ned-id
Possible completions:
  cisco-iosxr-cli-7.13  lsa-netconf  netconf  snmp  xr-nc-6.6
admin@ncs(config-device-xrv9k-controller)# device-type netconf ned-id xr-nc-6.6
admin@ncs(config-device-xrv9k-controller)# show config
admin@ncs(config-device-xrv9k-controller)# exit
admin@ncs(config)# show config
admin@ncs(config)# commit
Commit complete.
admin@ncs(config)#
admin@ncs(config)# exit
admin@ncs# show packages package oper-status
        PACKAGE
                          PROGRAM                                                        META     FILE
                          CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD
NAME                  UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  ERROR INFO
cisco-iosxr-cli-7.13  X   -        -              -        -        -        -           -        -      -
cn-to-dc              -   -        -              -        -        -        -           -        X      [cn-to-dc-template.xml:2 Unknown servicepoint: cn-to-dc]
dc-to-cn              -   -        -              -        -        -        -           -        X      [dc-to-cn-template.xml:2 Unknown servicepoint: dc-to-cn]
rpl                   X   -        -              -        -        -        -           -        -      -
xr-nc-6.6             X   -        -              -        -        -        -           -        -      -
admin@ncs#
admin@ncs# devices device xrv9k-controller sync-from
result false
info xrv9k-controller: invalid value for: assign in /ncs:devices/ncs:device[ncs:name='xrv9k-controller']/ncs:config/vm:vm/vm:config/vm:cpu/vm:assign: "" is an invalid value.
Could you kindly check how to fix the issue...
1 ACCEPTED SOLUTION
Re: netconf ned for xr662
“Cisco-IOS-XR-sysadmin-vm.yang has a violation of RFC 6087 YANG model guidelines, section 4.9. This will be corrected in future release.”
https://github.com/YangModels/yang/tree/master/vendor/cisco/xr/662
That is RCA? Need to exclude the yang file before build ned...?
Yes, after removing the yang, sync-from recovery to normal:
netconf-ned-builder project xr 6.6 module Cisco-IOS-XR-sysadmin-vm * deselect
1 REPLY 1
