Netconf / Yang for IOS XR
previousqna
Level 5
Level 5
Hi team,
I would like to ask you if there is a best practice recommendation available for netconf-yang agent configuration on IOS-XR nodes in regards to rate-limit and number of sessions.
RP/0/RSP0/CPU0:ASR9001-1(config)#netconf-yang agent ?
  rate-limit  Rate limit
  session     Session settings
  ssh         Enable NETCONF-YANG agent over SSH connection
  yfw         YANG Framework settings
RP/0/RSP0/CPU0:ASR9001-1(config)#netconf-yang agent session ?
  absolute-timeout  Absolute session lifetime
  idle-timeout      Non-active session lifetime
  limit             Maximum count of concurrent sessions (default = 50)
RP/0/RSP0/CPU0:ASR9001-1(config)#netconf-yang agent rate-limit ?
  <4096-4294967295>  Number of bytes to process per sec
Are there any other “crucial” things to consider in order to enable netconf / yang?
Thanks for your feedback.
previousqna
Level 5
Level 5
I usually leave these at default. For most part it works fine, but I have hit the max number of session limit sometimes when I download all the YANG files. When the client closes a session, it takes a bit of time before the XR considers it "returned", so even if you have a single client that serially and rapidly establishes new sessions, you may run out.
You are likely to encounter things here and there that do not yet work as expected. Be sure to report such findings back to the XR team (or to me) to make sure it's fixed asap.
Best Regards,
