NSO-6.0 Centos7.9 Install - (error) ZLIB-1.2.7.1 not found
lwarrin1964
Beginner
Beginner
The output message says to contact Cisco support for this issue.   The zlib lib repositories do now have zlib-1.2.7.1.  In a search through zlib - this one is not found.    Below is the output message.
[lwarring@sv-usplan-cnso06 nso-6.0]$ sudo ./nso-6.0.linux.x86_64.installer.bin --local-install localinstall/
INFO  Using temporary directory /tmp/ncs_installer.30099 to stage NCS installation bundle
INFO  Unpacked ncs-6.0 in /opt/nso/nso-6.0/localinstall/
INFO  Found and unpacked corresponding DOCUMENTATION_PACKAGE
INFO  Found and unpacked corresponding EXAMPLE_PACKAGE
INFO  Found and unpacked corresponding JAVA_PACKAGE
INFO  Generating default SSH hostkey (this may take some time)
INFO  SSH hostkey generated
INFO  Generating self-signed certificates for HTTPS
REQUIRED LIBRARIES NOT FOUND
/opt/nso/nso-6.0/localinstall//lib/ncs/erts/bin/ncs.smp: /lib64/libz.so.1: version `ZLIB_1.2.7.1' not found (required by /opt/nso/nso-6.0/localinstall//lib/ncs/erts/bin/ncs.smp)
You will need to install them before you will be able to run NSO.
You are welcome to ask your Cisco support contact for assistance.
INFO  Environment set-up generated in /opt/nso/nso-6.0/localinstall//ncsrc
INFO  NSO installation script finished
INFO  Found and unpacked corresponding NETSIM_PACKAGE
INFO  NCS installation complete
5 Replies 5
miott
Go to the NSO developer hub and submit your question there. https://community.cisco.com/t5/developer-networking/ct-p/j-developer-networking
u.avsec
Beginner
Beginner
I think NSO is saying it is time to move to something newer than CentOS 7.9. Or CentOS altogether, may it RIP
cohult
If you want to make NSO 6 run on Centos 7, you need to download the zlib source code and "make install" it replacing the old version that comes with Centos 7.
The zlib homepage. zlib.net, is gone, so you need to Google for something like "zlib 1.2.13" to get the source code tarball from somewhere.
cohult
Try following this guide https://www.codetd.com/en/article/10787113 but use the 1.2.13 version from for example https://github.com/madler/zlib/releases/tag/v1.2.13
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
