NSO crash due to ASA ned
Chris Wang
When I upgrade NSO from 4.6.1 to 4.7.5, everyday, when sync-from some ASA devices, NSO crashed, below is the error log, please help on that
The NEDs I used:
show packages package package-version
PACKAGE
NAME VERSION
cisco-asa 6.7.2
cisco-fmc 1.2.9
cisco-ios 6.33.7
cisco-iosxr 7.13.9
cisco-nx 5.11.2
citrix-netscaler 4.0.3
snmp-notif-recv 1.0
tailf-hcc 4.4.3
{"25-Sep-2019::14:40:00.660",
 {error_report,<0.497.0>,
     {<0.16845.5>,std_error,
      {webui_errormod_crash,27,
          {"\n\nERROR erlang code threw an uncaught exception:\n File: appmod:0\nClass: exit\nException: {noproc,{gen_server,call,\n                               [cs_usess,\n                                {close_session,11798,normal},\n                                infinity]}}\nReq: {http_request,'POST',\n                   {abs_path,\"/api/running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from\"},\n                   {1,1}}\nStack: [{gen_server,call,3,[{file,\"gen_server.erl\"},{line,223}]},\n        {rest,maybe_close_usess,2,[{file,\"rest.erl\"},{line,751}]},\n        {rest,out,1,[{file,\"rest.erl\"},{line,226}]},\n        {yaws_server,deliver_dyn_part,8,\n                     [{file,\"yaws_server.erl\"},{line,2838}]},\n        {yaws_server,aloop,4,[{file,\"yaws_server.erl\"},{line,1252}]},\n        {yaws_server,acceptor0,2,[{file,\"yaws_server.erl\"},{line,1076}]},\n        {proc_lib,init_p_do_apply,3,[{file,\"proc_lib.erl\"},{line,240}]}]\n",
           {arg,
               {ssl,
                   {sslsocket,
                       {gen_tcp,#Port<0.63314>,tls_connection,<0.525.0>},
                       <0.17069.5>}},
               {{10,240,214,60},59054},
               {headers,"Keep-Alive",undefined,"csgnso.webex.com",undefined,
                   undefined,undefined,undefined,undefined,undefined,
                   undefined,"unirest-java/1.3.11",undefined,[],undefined,
                   undefined,"0","application/vnd.yang.operation+json",
                   undefined,
                   {"ncsadmin","3ZpEDtdzJ4lO",
                    "Basic bmNzYWRtaW46M1pwRUR0ZHpKNGxP"},
                   [{http_header,1,'Cache-Control',undefined,"no-cache"},
                    {http_header,10,'Accept-Encoding',undefined,"gzip"}]},
                   {abs_path,
                       "/api/running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from"},
                   {1,1}},
                   {abs_path,
                   {1,1}},
               "/api/running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from",
               undefined,
               "running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from",
               "/opt/ncs/ncs-4.7.5/var/ncs/webui/dist/ncs","/",
               "/opt/ncs/ncs-4.7.5/var/ncs/webui/dist/ncs/api/running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from",
               undefined,undefined,<0.16845.5>,
               [{disable_auth,[]},
                {custom_headers,[]},
                {"vdir",
                 "/compliance-reports /var/opt/ncs/state/compliance-reports"}],
               "/running/devices/device/SIN01-WXVC-ASA01A/_operations/sync-from"}},
          [{gen_server,call,3,[{file,"gen_server.erl"},{line,223}]},
           {rest,maybe_close_usess,2,[{file,"rest.erl"},{line,751}]},
           {rest,out,1,[{file,"rest.erl"},{line,226}]},
               [{file,"yaws_server.erl"},{line,2838}]},
           {yaws_server,aloop,4,[{file,"yaws_server.erl"},{line,1252}]},
           {yaws_server,acceptor0,2,[{file,"yaws_server.erl"},{line,1076}]},
               [{file,"proc_lib.erl"},{line,240}]}]}}}}
0 Replies 0
