12-19-2018 02:54 PM
Trying to run through the getting starting guide and getting errors on the first example when doing a `devices connect`
admin@ncs# devices connect
connect-result {
device c0
result false
info Failed to connect to device c0: connection refused: Connection refused (Connection refused)
connect-result {
device c1
result false
info Failed to connect to device c1: connection refused: Connection refused (Connection refused)
connect-result {
device c2
result false
info Failed to connect to device c2: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c0: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c2: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c1: connection refused: Connection refused (Connection refused)
admin@ncs#
12-19-2018 04:49 PM
I assume these are netsim devices.
Did you go to the requested directory and perform the desired steps?
Go to examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios. ### In the install directory, follow the requested path
$ ncs-netsim create-network $NCS_DIR/packages/neds/cisco-ios 3 c
then perform the:
ncs-netsim start ## starts the 3 created netsim devices
And try to connect to the generated netsim devices.
Where exactly did you stop in the documentation?
12-19-2018 04:59 PM
$ ncs-setup --netsim-dir ./netsim --dest .## must be defined as well.
12-20-2018 01:36 AM
I just played with the same example and I get the same response as you if I stop my netsim devcies and then try to re-connect.
try "ncs-netsim status" and see if they are started.
i.e.
connect-result {
device c2
result false
[ok][2018-12-20 10:27:32]
admin@ncs> *** ALARM connection-failure: Failed to connect to device c1: connection refused: Connection refused
12-20-2018 08:46 AM
:~/nso-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios$ ncs-netsim status
DEVICE c0
connection refused (status)
DEVICE c1
DEVICE c2
12-20-2018 12:51 PM
I have tried on both Mac and Ubuntu. See the 2 sections below
On mac:
=> ncs-netsim status DEVICE c0 ./env.sh: line 12: export: `Fusion.app/Contents/Public:/Library/TeX/texbin:/opt/X11/bin:/Library/Frameworks/Mono.framework/Versions/Current/Commands:/usr/local/bin:/Users/smolz/bin:/Users/smolz/.rvm/bin:/Users/smolz/.rvm/bin': not a valid identifier vsn: 6.7 SMP support: no Using epoll: no available modules: backplane,netconf,cdb,cli,snmp,webui running modules: backplane,netconf,cdb,cli status: started namespaces: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix:ianach exported to: all urn:ietf:params:xml:ns:yang:ietf-inet-types prefix:inet exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix:nacm exported to: none urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix:ncm exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix:ncn exported to: all urn:ietf:params:xml:ns:yang:ietf-restconf prefix:rc exported to: rest urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix:rcmon exported to: all urn:ietf:params:xml:ns:yang:ietf-yang-library prefix:yanglib exported to: netconf,rest urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix:ypatch exported to: rest urn:ietf:params:xml:ns:yang:ietf-yang-types prefix:yang exported to: all http://tail-f.com/ns/aaa/1.1 prefix:aaa exported to: none http://tail-f.com/yang/acm prefix:tacm exported to: all http://tail-f.com/yang/common prefix:tailf exported to: all http://tail-f.com/yang/common-monitoring prefix:tfcg exported to: all http://tail-f.com/ns/common/query prefix:tfcq exported to: all http://tail-f.com/yang/confd-monitoring prefix:tfcm exported to: all http://tail-f.com/ns/kicker prefix:kicker exported to: all urn:ios prefix:ios exported to: all http://tail-f.com/yang/netconf-monitoring prefix:tncm exported to: all http://tail-f.com/ns/progress prefix:progress exported to: all http://tail-f.com/ns/rollback prefix:rollback exported to: rest,netconf,maapi http://tail-f.com/ns/webui prefix:webui exported to: all http://tail-f.com/yang/xsd-types prefix:xs exported to: all YANG data models: module: iana-crypt-hash revision: 2014-08-06 namespace: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix: ianach exported to: all module: ietf-inet-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-inet-types prefix: inet exported to: all module: ietf-netconf-acm revision: 2012-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix: nacm exported to: none module: ietf-netconf-monitoring revision: 2010-10-04 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix: ncm exported to: all module: ietf-netconf-notifications revision: 2012-02-06 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix: ncn exported to: all module: ietf-restconf revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf prefix: rc exported to: rest module: ietf-restconf-monitoring revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix: rcmon exported to: all module: ietf-yang-library revision: 2016-06-21 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-library prefix: yanglib exported to: netconf,rest module: ietf-yang-patch revision: 2017-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix: ypatch exported to: rest module: ietf-yang-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-types prefix: yang exported to: all module: tailf-aaa revision: 2015-06-16 namespace: http://tail-f.com/ns/aaa/1.1 prefix: aaa exported to: none module: tailf-acm revision: 2013-03-07 namespace: http://tail-f.com/yang/acm prefix: tacm exported to: all module: tailf-common revision: 2018-04-19 namespace: http://tail-f.com/yang/common prefix: tailf exported to: all module: tailf-common-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/common-monitoring prefix: tfcg exported to: all module: tailf-common-query revision: 2017-12-15 namespace: http://tail-f.com/ns/common/query prefix: tfcq exported to: all module: tailf-confd-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/confd-monitoring prefix: tfcm exported to: all module: tailf-kicker revision: 2017-09-28 namespace: http://tail-f.com/ns/kicker prefix: kicker exported to: all module: tailf-ned-cisco-ios revision: 2014-02-12 namespace: urn:ios prefix: ios exported to: all module: tailf-netconf-monitoring revision: 2016-11-24 namespace: http://tail-f.com/yang/netconf-monitoring prefix: tncm exported to: all module: tailf-progress revision: 2018-06-21 namespace: http://tail-f.com/ns/progress prefix: progress exported to: all module: tailf-rollback revision: 2018-01-12 namespace: http://tail-f.com/ns/rollback prefix: rollback exported to: rest,netconf,maapi module: tailf-webui revision: 2013-03-07 namespace: http://tail-f.com/ns/webui prefix: webui exported to: all module: tailf-xsd-types revision: 2017-11-20 namespace: http://tail-f.com/yang/xsd-types prefix: xs exported to: all user sessions: system sessions: sessionId=1 2018-12-20 08:52:14 system@0.0.0.0 system/system no locks set no transactions sessionId=10 2018-12-20 08:52:14 system@0.0.0.0 system/system no locks set no transactions sessionId=11 2018-12-20 08:52:14 system@0.0.0.0 system/system no locks set no transactions sessionId=12 2018-12-20 08:52:14 system@0.0.0.0 system/system no locks set transactions: tid=7 db=running mode=read callpoints: validation points: actionpoints: typepoints: notification stream replay support: SNMP inform delivery callbacks: SNMP notification subscriptions: authentication callback: not enabled authorization callbacks: not enabled error formatting callbacks: partial running locks: partial candidate locks: partial startup locks: cdb: current transaction id: 1545-324734-697436 running: ram size: 17.3 kB read locks: 0 write lock: unset startup: filename: ./cdb/A.cdb disk size: 2.0 kB ram size: 17.1 kB read locks: 0 write lock: unset operational: filename: ./cdb/O.cdb disk size: 4 bytes ram size: 136 bytes subscription lock: unset no pending subscription notifications no registered cdb clients tts alloc: 43175 40:50:20 64:280:0 72:35:0 120:10:0 176:57:246 DEVICE c1 ./env.sh: line 12: export: `Fusion.app/Contents/Public:/Library/TeX/texbin:/opt/X11/bin:/Library/Frameworks/Mono.framework/Versions/Current/Commands:/usr/local/bin:/Users/smolz/bin:/Users/smolz/.rvm/bin:/Users/smolz/.rvm/bin': not a valid identifier vsn: 6.7 SMP support: no Using epoll: no available modules: backplane,netconf,cdb,cli,snmp,webui running modules: backplane,netconf,cdb,cli status: started namespaces: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix:ianach exported to: all urn:ietf:params:xml:ns:yang:ietf-inet-types prefix:inet exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix:nacm exported to: none urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix:ncm exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix:ncn exported to: all urn:ietf:params:xml:ns:yang:ietf-restconf prefix:rc exported to: rest urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix:rcmon exported to: all urn:ietf:params:xml:ns:yang:ietf-yang-library prefix:yanglib exported to: netconf,rest urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix:ypatch exported to: rest urn:ietf:params:xml:ns:yang:ietf-yang-types prefix:yang exported to: all http://tail-f.com/ns/aaa/1.1 prefix:aaa exported to: none http://tail-f.com/yang/acm prefix:tacm exported to: all http://tail-f.com/yang/common prefix:tailf exported to: all http://tail-f.com/yang/common-monitoring prefix:tfcg exported to: all http://tail-f.com/ns/common/query prefix:tfcq exported to: all http://tail-f.com/yang/confd-monitoring prefix:tfcm exported to: all http://tail-f.com/ns/kicker prefix:kicker exported to: all urn:ios prefix:ios exported to: all http://tail-f.com/yang/netconf-monitoring prefix:tncm exported to: all http://tail-f.com/ns/progress prefix:progress exported to: all http://tail-f.com/ns/rollback prefix:rollback exported to: rest,netconf,maapi http://tail-f.com/ns/webui prefix:webui exported to: all http://tail-f.com/yang/xsd-types prefix:xs exported to: all YANG data models: module: iana-crypt-hash revision: 2014-08-06 namespace: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix: ianach exported to: all module: ietf-inet-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-inet-types prefix: inet exported to: all module: ietf-netconf-acm revision: 2012-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix: nacm exported to: none module: ietf-netconf-monitoring revision: 2010-10-04 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix: ncm exported to: all module: ietf-netconf-notifications revision: 2012-02-06 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix: ncn exported to: all module: ietf-restconf revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf prefix: rc exported to: rest module: ietf-restconf-monitoring revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix: rcmon exported to: all module: ietf-yang-library revision: 2016-06-21 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-library prefix: yanglib exported to: netconf,rest module: ietf-yang-patch revision: 2017-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix: ypatch exported to: rest module: ietf-yang-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-types prefix: yang exported to: all module: tailf-aaa revision: 2015-06-16 namespace: http://tail-f.com/ns/aaa/1.1 prefix: aaa exported to: none module: tailf-acm revision: 2013-03-07 namespace: http://tail-f.com/yang/acm prefix: tacm exported to: all module: tailf-common revision: 2018-04-19 namespace: http://tail-f.com/yang/common prefix: tailf exported to: all module: tailf-common-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/common-monitoring prefix: tfcg exported to: all module: tailf-common-query revision: 2017-12-15 namespace: http://tail-f.com/ns/common/query prefix: tfcq exported to: all module: tailf-confd-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/confd-monitoring prefix: tfcm exported to: all module: tailf-kicker revision: 2017-09-28 namespace: http://tail-f.com/ns/kicker prefix: kicker exported to: all module: tailf-ned-cisco-ios revision: 2014-02-12 namespace: urn:ios prefix: ios exported to: all module: tailf-netconf-monitoring revision: 2016-11-24 namespace: http://tail-f.com/yang/netconf-monitoring prefix: tncm exported to: all module: tailf-progress revision: 2018-06-21 namespace: http://tail-f.com/ns/progress prefix: progress exported to: all module: tailf-rollback revision: 2018-01-12 namespace: http://tail-f.com/ns/rollback prefix: rollback exported to: rest,netconf,maapi module: tailf-webui revision: 2013-03-07 namespace: http://tail-f.com/ns/webui prefix: webui exported to: all module: tailf-xsd-types revision: 2017-11-20 namespace: http://tail-f.com/yang/xsd-types prefix: xs exported to: all user sessions: system sessions: sessionId=1 2018-12-20 08:52:15 system@0.0.0.0 system/system no locks set no transactions sessionId=10 2018-12-20 08:52:15 system@0.0.0.0 system/system no locks set no transactions sessionId=11 2018-12-20 08:52:15 system@0.0.0.0 system/system no locks set no transactions sessionId=12 2018-12-20 08:52:15 system@0.0.0.0 system/system no locks set transactions: tid=7 db=running mode=read callpoints: validation points: actionpoints: typepoints: notification stream replay support: SNMP inform delivery callbacks: SNMP notification subscriptions: authentication callback: not enabled authorization callbacks: not enabled error formatting callbacks: partial running locks: partial candidate locks: partial startup locks: cdb: current transaction id: 1545-324735-936486 running: ram size: 17.2 kB read locks: 0 write lock: unset startup: filename: ./cdb/A.cdb disk size: 2.0 kB ram size: 17.1 kB read locks: 0 write lock: unset operational: filename: ./cdb/O.cdb disk size: 4 bytes ram size: 136 bytes subscription lock: unset no pending subscription notifications no registered cdb clients tts alloc: 43191 40:50:20 64:284:0 72:30:0 120:11:0 176:57:246 DEVICE c2 ./env.sh: line 12: export: `Fusion.app/Contents/Public:/Library/TeX/texbin:/opt/X11/bin:/Library/Frameworks/Mono.framework/Versions/Current/Commands:/usr/local/bin:/Users/smolz/bin:/Users/smolz/.rvm/bin:/Users/smolz/.rvm/bin': not a valid identifier vsn: 6.7 SMP support: no Using epoll: no available modules: backplane,netconf,cdb,cli,snmp,webui running modules: backplane,netconf,cdb,cli status: started namespaces: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix:ianach exported to: all urn:ietf:params:xml:ns:yang:ietf-inet-types prefix:inet exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix:nacm exported to: none urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix:ncm exported to: all urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix:ncn exported to: all urn:ietf:params:xml:ns:yang:ietf-restconf prefix:rc exported to: rest urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix:rcmon exported to: all urn:ietf:params:xml:ns:yang:ietf-yang-library prefix:yanglib exported to: netconf,rest urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix:ypatch exported to: rest urn:ietf:params:xml:ns:yang:ietf-yang-types prefix:yang exported to: all http://tail-f.com/ns/aaa/1.1 prefix:aaa exported to: none http://tail-f.com/yang/acm prefix:tacm exported to: all http://tail-f.com/yang/common prefix:tailf exported to: all http://tail-f.com/yang/common-monitoring prefix:tfcg exported to: all http://tail-f.com/ns/common/query prefix:tfcq exported to: all http://tail-f.com/yang/confd-monitoring prefix:tfcm exported to: all http://tail-f.com/ns/kicker prefix:kicker exported to: all urn:ios prefix:ios exported to: all http://tail-f.com/yang/netconf-monitoring prefix:tncm exported to: all http://tail-f.com/ns/progress prefix:progress exported to: all http://tail-f.com/ns/rollback prefix:rollback exported to: rest,netconf,maapi http://tail-f.com/ns/webui prefix:webui exported to: all http://tail-f.com/yang/xsd-types prefix:xs exported to: all YANG data models: module: iana-crypt-hash revision: 2014-08-06 namespace: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix: ianach exported to: all module: ietf-inet-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-inet-types prefix: inet exported to: all module: ietf-netconf-acm revision: 2012-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix: nacm exported to: none module: ietf-netconf-monitoring revision: 2010-10-04 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix: ncm exported to: all module: ietf-netconf-notifications revision: 2012-02-06 namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix: ncn exported to: all module: ietf-restconf revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf prefix: rc exported to: rest module: ietf-restconf-monitoring revision: 2017-01-26 namespace: urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix: rcmon exported to: all module: ietf-yang-library revision: 2016-06-21 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-library prefix: yanglib exported to: netconf,rest module: ietf-yang-patch revision: 2017-02-22 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix: ypatch exported to: rest module: ietf-yang-types revision: 2013-07-15 namespace: urn:ietf:params:xml:ns:yang:ietf-yang-types prefix: yang exported to: all module: tailf-aaa revision: 2015-06-16 namespace: http://tail-f.com/ns/aaa/1.1 prefix: aaa exported to: none module: tailf-acm revision: 2013-03-07 namespace: http://tail-f.com/yang/acm prefix: tacm exported to: all module: tailf-common revision: 2018-04-19 namespace: http://tail-f.com/yang/common prefix: tailf exported to: all module: tailf-common-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/common-monitoring prefix: tfcg exported to: all module: tailf-common-query revision: 2017-12-15 namespace: http://tail-f.com/ns/common/query prefix: tfcq exported to: all module: tailf-confd-monitoring revision: 2013-06-14 namespace: http://tail-f.com/yang/confd-monitoring prefix: tfcm exported to: all module: tailf-kicker revision: 2017-09-28 namespace: http://tail-f.com/ns/kicker prefix: kicker exported to: all module: tailf-ned-cisco-ios revision: 2014-02-12 namespace: urn:ios prefix: ios exported to: all module: tailf-netconf-monitoring revision: 2016-11-24 namespace: http://tail-f.com/yang/netconf-monitoring prefix: tncm exported to: all module: tailf-progress revision: 2018-06-21 namespace: http://tail-f.com/ns/progress prefix: progress exported to: all module: tailf-rollback revision: 2018-01-12 namespace: http://tail-f.com/ns/rollback prefix: rollback exported to: rest,netconf,maapi module: tailf-webui revision: 2013-03-07 namespace: http://tail-f.com/ns/webui prefix: webui exported to: all module: tailf-xsd-types revision: 2017-11-20 namespace: http://tail-f.com/yang/xsd-types prefix: xs exported to: all user sessions: system sessions: sessionId=1 2018-12-20 08:52:16 system@0.0.0.0 system/system no locks set no transactions sessionId=10 2018-12-20 08:52:17 system@0.0.0.0 system/system no locks set no transactions sessionId=11 2018-12-20 08:52:17 system@0.0.0.0 system/system no locks set no transactions sessionId=12 2018-12-20 08:52:17 system@0.0.0.0 system/system no locks set transactions: tid=7 db=running mode=read callpoints: validation points: actionpoints: typepoints: notification stream replay support: SNMP inform delivery callbacks: SNMP notification subscriptions: authentication callback: not enabled authorization callbacks: not enabled error formatting callbacks: partial running locks: partial candidate locks: partial startup locks: cdb: current transaction id: 1545-324737-174921 running: ram size: 17.1 kB read locks: 0 write lock: unset startup: filename: ./cdb/A.cdb disk size: 2.0 kB ram size: 17.1 kB read locks: 0 write lock: unset operational: filename: ./cdb/O.cdb disk size: 4 bytes ram size: 136 bytes subscription lock: unset no pending subscription notifications no registered cdb clients tts alloc: 43039 40:50:20 64:285:0 72:32:0 120:8:0 176:57:246 _______________________________________ | ~/ncs-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios @ iMacistan (smolz) | =>
On Ubuntu:
ubuntu:~/nso-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios$ ncs-netsim status DEVICE c0 connection refused (status) DEVICE c1 connection refused (status) DEVICE c2 connection refused (status)
12-20-2018 01:42 PM
Hi, so i think i know what the issue is/was.
Josephs-MacBook-Pro:1-simulated-cisco-ios jleepak$ ncs-setup --netsim-dir ./netsim --dest .
Using netsim dir ./netsim
I stopped NSO due to my previous instance being up via ncs --stop. Started NSO
Josephs-MacBook-Pro:1-simulated-cisco-ios jleepak$ ncs_cli -C -u admin
admin connected from 127.0.0.1 using console on Josephs-MacBook-Pro.local
admin@ncs# show devices list
NAME ADDRESS DESCRIPTION NED ID ADMIN STATE
c0 127.0.0.1 - cisco-ios unlocked
c1 127.0.0.1 - cisco-ios unlocked
c2 127.0.0.1 - cisco-ios unlocked
connect-result {
device c0
result true
info (admin) Connected to c0 - 127.0.0.1:10022
What I think you did was forgetting to set up the netsim-dir in the examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios directory.
You must remain in the directory of the desired samples.
02-10-2019 05:22 PM
Not true. I did follow the examples. set the netsim folder to the examples folder.
I got the same error , connection refused.
02-11-2019 01:51 PM
02-11-2019 02:06 PM
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
