NSO NACM Data Node Rule for a device
ZAhmad04890
I have created a new user in NSO named user1 and restricted access to device PE0 using the data Node rule as below
nacm groups group user1
user-name [ user1 public ]
nacm rule-list user1
 group [ user1 ]
 rule  BLOCK-PE0
 path  devices/device[name='PE0']
 access-operations  create,read,update,delete
 action  deny
However when I login in NSO using user1 , the device PE0 is not blocked for the user1 , and i can still make changes to the device PE0 using NSO, what can I do in above configuration , that all the changes to the device PE0 are blocked for the user user1 ?
Thanks & Regards
vleijon
Your path has to start with /devices/device at least.
5 Replies 5
vleijon
Hi vleijon,
when I am logging in NSO with a user other than admin, I cannot see the NACM rules is the running configuration of NSO, neither i can modify any NACM configuration, are the NACM rules only accessible via admin user on NSO ? and also NACM config can be modified only via admin user ?
Thanks.
The editing of NACM rules also follows the NACM rules, so it will depend on your configuration. Generally, since being allowed to edit the NACM rules indirectly gives you access to everything it make sense to restrict access.
Does that mean that we can create a new account in NSO and can give it administrative privileges equal to admin?
Yes, the name admin is not special in any way, it is all driven by the rules.
