02-05-2020 07:56 AM
Hi everyone,
I have a few questions about NSO
1- How can I deploy the same service multiple times on the same device ?
Let me show you what i mean ( i have to post imgur images because it seems like i'm not able to upload them otherwhise)
This is our service "interface configuration" : https://i.imgur.com/Pi2VyJ6.png
If i try to apply the service once more to the same device (eg: https://i.imgur.com/QjJg927.png)
I get an error message : https://i.imgur.com/PoxFbiW.png
Why does this happen only with this service? If i try to do the same thing with our "simple_acl" service it lets me apply the service multiple times : https://i.imgur.com/RoCFsYx.png
It would actually be great if there was a way to make me config all the interfaces I want from a given device, without having to apply multiple times the same service to the same device. You can find the .yang of the service attached, I'm opened to any suggestion.
2- Is it possible to recall all the existing interfaces in a device instead of only a given type? How?
What I mean by that is:
choice interface {
case ios-GigabitEthernet {
leaf GigabitEthernet {
type leafref {
path "deref(../device)/../ncs:config/ios:interface/ios:GigabitEthernet/ios:name";
} //case ios-Gigabit
case ios-TenGigabitEthernet {
leaf TenGigabitEthernet {
type leafref {
path "deref(../device)/../ncs:config/ios:interface/ios:TenGigabitEthernet/ios:name";
} //case ios-TenGigabit
I'm recalling interfaces on a per-type basis, because i'm not able to recall all the interfaces in the device, is there any other way to do that? The interface-conf.yang is always attached
3- Why doesn't NSO GUI show me the "parameters" configuration if I don't put it under a "choice" ?
If i use containers It actually appears as fillable but when i go to the configuration manager to apply the configuration nothing shows up under the "native" configuration, that means that the device won't apply any configuration. The "choice" i made in the yang file (attached) is only a work-around to make it actually appear.
Thanks in advance!
-G.I.
02-05-2020 08:52 AM
The YANG model defines the interface as a leaf and not leaf-list or list, so, there is only one possible per device, as device is the service key.
02-06-2020 07:45 AM
Ok,thank you very much, the first point is clear then, have you any other hints on the other ones?
