NSO RESTCONF Sync-From fails with NEDCOM CONNECT : Authenticate Error
All,
I'm working through the RESTCONF API to get a device added, fetch-keys and sync-from.
My device add and fetch keys API calls are working
I'm attempting to invoke a sync-from on a deployed dev-csr device but it's failing
The sync-from works via ncs_cli without issue.
When attempting it from RESTCONF API I get the following JSON response
"tailf-ncs:output": {
        "result": false,
         "info": "Failed to connect to device dev-csr: connection refused: NEDCOM CONNECT: Authenticate: Exhausted available
          authentication methods. Server allowed: [ publickey keyboard-interactive password ] in new state"
Am I incorrect to think any authentication parameters for the NED would be defined by the authgroup configured and appear to be working properly when I sync-from using CLI?
Any direction on troubleshooting this please.
-Scott
radioman
Hi Scoot
Looks a bit like a problem I ran across last year, do you see log lines like this on the CSR ?
RP/0/RP0/CPU0:Apr 8 14:07:12.995 CEST: SSHD_[1297]: %SECURITY-SSHD-6-INFO_GENERAL : Incoming SSH session rate limit exceeded
If that is the case you are doing the fetch-keys and sync-from too fast, and are hitting the default rate-limit of 1 connection pr. second on the device. eg. have a look at this manual:
https://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r5-3/security/command/reference/b-syssec-cr-53xcrs/b-syssec-cr-53xcrs_chapter_01000.html#wp1423655881
You could try to increase "ssh server rate-limit" to eg. 180 or insert some delay in your code.
br.
Kristoffer Laresn
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
