Highlighted
NSO Rollback History Length
Hi i know NSO will only hold history for the last 500 commits, but is this number configurable where can i configure it ?
Yale
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: NSO Rollback History Length
2 REPLIES 2
Highlighted
Highlighted
Not sure where the number 500 is from. You can configure it in ncs.conf, under /ncs-config/rollback/history-size
$ man ncs.conf
/ncs-config/rollback/history-size (uint32) [35]
Number of old configurations to save.
/Ram
