OpenSSL might not be installed on this system
sisambas
Dear ConfD Team,
In our product ESC (Elastic service controller),
we are upgrading from confd 661 to 763.
We are getting the below errors while starting confd
[root@dnd-sisambas-confd753b-debug1 lib64]# sudo runuser -s /bin/sh - esc-user -c "cd /opt/cisco/esc/esc-confd; /opt/cisco/esc/confd/bin/confd --foreground -c /opt/cisco/esc/esc_database/esc_production_confd.conf --addloadpath /opt/cisco/esc/confd/etc/confd --addloadpath /opt/cisco/esc/esc-confd/YANGmodels-tailf"
<COMPLETE ERROR SNIPPET>
=ERROR REPORT==== 7-Jan-2022::11:38:38.417606 ===
Unable to load crypto library. Failed with error:
"load_failed, Failed to load NIF library: '/opt/cisco/esc/confd/lib/confd/lib/core/crypto/priv/lib/crypto.so: undefined symbol: ENGINE_unregister_STORE'"
OpenSSL might not be installed on this system.
=WARNING REPORT==== 7-Jan-2022::11:38:38.444382 ===
The on_load function for module crypto returned:
{error,{load_failed,"Failed to load NIF library: '/opt/cisco/esc/confd/lib/confd/lib/core/crypto/priv/lib/crypto.so: undefined symbol: ENGINE_unregister_STORE'"}}
=ERROR REPORT==== 7-Jan-2022::11:38:38.450360 ===
=WARNING REPORT==== 7-Jan-2022::11:38:38.451010 ===
"Bad configuration: /opt/cisco/esc/esc_database/esc_production_confd.conf:0: cannot dynamically link with libcrypto shared library\n"
=ERROR REPORT==== 7-Jan-2022::11:38:38.453158 ===
init:boot_msg: "Bad configuration: /opt/cisco/esc/esc_database/esc_production_confd.conf:0: cannot dynamically link with libcrypto shared library\n"
</COMPLETE ERROR SNIPPET>
Other outputs captured for debugging:
output1)
[root@dnd-sisambas-confd753b-debug1 opt]# ldd /opt/confd-7.5.3/lib/confd/lib/core/crypto/priv/lib/crypto.so
linux-vdso.so.1 (0x00007ffd373ed000)
libcrypto.so.1.1 => /lib64/libcrypto.so.1.1 (0x00007fc4f4e8c000)
libc.so.6 => /lib64/libc.so.6 (0x00007fc4f4ac7000)
libz.so.1 => /lib64/libz.so.1 (0x00007fc4f48b0000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fc4f46ac000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fc4f448c000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc4f558e000)
output2)
[root@dnd-sisambas-confd753b-debug1 ~]# rpm -qa | grep openssl
openssl-1.1.1g-15.el8_3.x86_64
openssl-libs-1.1.1g-15.el8_3.x86_64
Could you please help in finding the reason for this error:
(This is little urgent as we are planning for the upgrade in this release..)
Thanks & Best Regards,
Siva
Nicklas Wagerth
Community Manager
Community Manager
Hello Siva! Note that this forum is about NSO. For ConfD related issues use the ConfD forum at: https://discuss.tail-f.com/
/Nicklas
Nicklas Wagerth
Community Manager
Community Manager
/Nicklas
