"FAILURE: no_networking commit failed with exception: wrong state (17)
gkhaled
hello all ,
i am trying to send commit no-networking  via commit param then i need to do reconcile after it , but when i tested that i received the following error :
"FAILURE: no_networking commit failed with exception: operation in wrong state (17): ",
elif input.commit_type == "no_networking":
                                try:
                                    # Validate the transaction
                                    t.validate(unlock=False)
                                    self.response_log(output, "Transaction validated successfully.")
                                    params = ncs.maapi.CommitParams()
                                    params.no_networking()
                                    result_no_networking = t.apply_params(True, params)
                                    if result_no_networking != 0:
                                        output.result = f"FAILURE: no_networking commit failed with code {result_no_networking}"
                                    else:
                                        output.result = "SUCCESS"
                                except Exception as e:
                                    output.result = f"FAILURE: no_networking commit failed with exception: {str(e)}"
                                    return
                                # New transaction for reconcile_keep_non_service_config
                                try:
                                    with ncs.maapi.single_write_trans(m, uinfo.username, db=ncs.RUNNING) as t2:
                                        params_reconcile = ncs.maapi.CommitParams()
                                        params_reconcile.reconcile_keep_non_service_config()
                                        result_reconcile = t2.apply_params(True, params_reconcile)
                                        if result_reconcile != 0:
                                            output.result = f"FAILURE: Reconcile commit failed with code {result_reconcile}"
                                            return
                                    output.result = f"FAILURE: Reconcile commit failed with exception: {str(e)}"
                                    return
so can any one help please .
cohult
Hi, usually there is an error message after the comma in "operation in the wrong state (17):"
The most common reasons for this error message when applying/committing configuration are that NSO is in read-only mode in an HA setup or that NSO is in a startup phase.
hi ,
it worked fine with me now when change  the single write trans to the following :
try:
                                    with ncs.maapi.single_write_trans(uinfo.username, 'python') as t2:
                                        self.response_log(output, f"Reconcile result is : {result_reconcile}")
                                        if result_reconcile != {}:
                                        else:
                                            self.response_log(output, f"SUCCESS: Commit Reconcile Keep service config succeeded.")
                                    return
