04-02-2019 05:17 AM
Hi All,
Do we have some reusable packages in NSO for l3vpn?
Most of the functions of l3vpn would be same, we just need to change part of it according to customer demand.
So why not use a template package for developing?
Or have tried but give up?
Solved! Go to Solution.
04-08-2019 07:14 AM
Yes, there are several included in your NSO installation. Look in
examples.ncs/service-provider/simple-mpls-vpn/ (this one uses templates only - no code)
examples.ncs/getting-started/developing-with-ncs/17-mpls-vpn-python/ (uses Python code in order to traverse the topology model connecting CE to PE)
examples.ncs/service-provider/mpls-vpn (same as previous, but uses Java code)
examples.ncs/service-provider/mpls-vpn-layered-service-architecture/ (layered service architecture (LSA) lets you distribute the application over multiple servers for scale)
04-08-2019 07:14 AM
