sync from return false
eee1
Hi All,
I am running
user@ncs# devices device vewlc-tre sync-from
result false
info vewlc-tre: missing element: profile-name in /ncs:devices/ncs:device[ncs:name='vewlc-tre']/ncs:config/wireless-wlan-cfg:wlan-cfg-data/wireless-wlan-cfg:wlan-cfg-entries/wireless-wlan-cfg:wlan-cfg-entry
Does anybody knows how to fix it?
I have also tried to remove the wlan module:
devices device vewlc-tre pioneer yang enable name-pattern  Cisco-IOS-XE-wireless-wlan-cfg*
But I still get the same.
Thanks for your help
vleijon
Hi.
It helps if you name the NED that you are using, in this case I am guessing from the context that you run NETCONF towards an IOS-XE device?
It looks here like there is a list wlan-cfg-entry where the NED assumes there will be a profile-name available but where no profile-name is found in the data from the device.
Your best bet here is to turn on the traces towards the device (set devices global-settings trace raw), and redoing the sync-from and looking in the netconf trace for how that piece of the XML looks, and comparing it to the YANG models you are using.
vleijon
Hi.
