Highlighted
Beginner
tailf-query nested foreach
Using the tailf-query call and was wondering if it is possible to perform a nested foreach query. For example with cisco-ios ned I want to grab all the interface descriptions, but in the same query foreach over all the subinterface descriptions as well.
Config:
interface GigabitEthernet0/0/1
 description parent description topmost
 service instance 1 ethernet
   description evc description 1
 service instance 20 ethernet
   description evc description 20
 service instance 30 ethernet
   description evc description 30
end
I have a call that will work fine to loop over the Gig interfaces and pull topmost description:
"immediate-query": {
"foreach": "/devices/device[name='LAB920']/config/ios:interface/GigabitEthernet",
"select": [
"label": "int_name",
"expression": "name",
"result-type": ["string"]
"label": "top_description",
"expression": "description",
"sort-by": ["name"],
"limit": 1000,
"offset": 1
Is it possible to add in the same query a nested foreach statement that will grab things like the service instance description as well?
