01-30-2019 12:21 AM
I'm looking for the latest NED for alu-sr and huawei-vrp in NSO 4.7.
First, the device is Nokia-7750SR-7s (alu), and I checked it with ncs-4.7-alu-sr-7.10.1.signed.bin.
I have compared the differences the device config and sync-from config, and there are a lot missing part.. (please find the attached file which is configuration from from the device)
The most important missing CLI is ‘connector’ under ‘port’ as below;
The port 1/1/c1 is 100G interface and they can configure it as logically segregated interfaces.
Would you please if this CLI (connector – breakout) are not supported currently?
If so, is there any work around until this feature will be supported?
configure
port 1/1/c1
shutdown
connector <<<<<<<<<<<<<<<<
breakout c4-10g <<<<<<<<<
exit
exit
Solved! Go to Solution.
01-30-2019 12:36 AM
It is normal for a NED to be incomplete. We only develop as much as is required for its current usage. Hence you are likely to have a use case that requires configuration that has not yet been required by anybody else. If your customer requires additional configuration support in a NED then please raise a request as per the standard process.
01-30-2019 11:02 AM
That is expected of the NED. You'll have to raise a TAC case to have the NED enhanced.
To properly raise a case with TAC and for expedited support, you should prepare the following for your SR:
-device trace in raw format, disconnect/connect to the device, do 'devices clear-trace', sync-from to the device that has the desired configurations
-Show on the real device CLI how to configure the desired command/s and provide the interface config output (or any config output relating to what commands you want added)
-and if you want, further verifications would be to simply show that the commands are missing in NSO cdb via show running/full.
Thank you.
01-30-2019 12:36 AM
01-30-2019 11:02 AM
Thank you.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
