05-03-2018 01:05 AM - edited 03-01-2019 04:09 AM
Hi Experts,
When we have time bound activities like smart license, when it come to NSO what would be best approach to check/validate the license status. In the NSO I heard about subscribers, kickers and nano services which one would be the best practice/approach for the "smart licensing". Can you give an example for nano services as well.
Else I need use time bound loop or infinite with sleep to check smart licensing. Assuming you have better way than this.
Kiran Kumar
05-03-2018 01:26 AM
I assume you are referring to the smart licensing status of the network device? Can you give an example of the command you would issue on the device in order to check the license status?
05-03-2018 02:24 AM
Yes and it's enabled in the device. So I need not to give pak file anymore I just enter the idtoken which verify with cisco and gives an update to the device. I generally using the following command to issue and check the status.
encs-host1# license smart register idtoken xxxxxxxxxxxxxxxxxxxxxxx
encs-host1# show license status
Smart Licensing is ENABLED
Registration:
Status: XXXXX
XXXXXX
License Authorization:
Status: XXXXX
XXXXXX
encs-host1#
05-03-2018 02:31 AM
Ok, now we have concluded that you are talking to an ENCS device, which has native NETCONF/YANG support, which I would assume includes the operational/status data like this. Now perhaps the NSO experts (i.e. the real experts ☺ ) can chime in on your question – how can an NSO application detect changes to a status value?
05-03-2018 06:00 AM
You can potentially write an Action to issue these commands towards a list of devices. Then use the NSO scheduler to call it periodically.
Not sure how well it will scale though.
admin@ncs(config)# scheduler
Possible completions:
suspend Suspend all tasks in the scheduler.
task Examples: Run sync-from on all devices 2 AM on the 1st every month: name: sync schedule: 0 2 1
* * action-name: sync-from action-node: /devices Purge the completed queue-item list 4:30 AM
every Sunday: name: purge schedule: 30 4 * * 0 action-name: purge action-node:
/devices/commit-queue/completed
05-03-2018 08:18 AM
Does the show license status data stores in CDB when I do sync-from ? If yes, can you please list the show commands stored in CDB.
I was in a impression it saves only running configuration.
And the scheduler is not the way i am looking for, any other way?
