Highlighted
Beginner
To compile or not to compile ..
I have an NSO production installation ad a sibling one devoted to test and integration.
I use to compile the new packages in the production environment as part of the deployment procedure. I see it is possible to load a new package already compiled, without recompiling it, though.
Which is the best practice? Is there any drawback in loading a package compiled in an other installation (with the same NSO versione)?
1 ACCEPTED SOLUTION
Highlighted
Agree with Viktor. Moreover, this is one of the main reasons why people want to use containers in production to make the NSO installation immutable: you use in production exactly what you tested.
2 REPLIES 2
Highlighted
Generally, I would recommend not recompiling. It is better to test exactly the thing that goes into production, and it saves you from the risk that something goes wrong on recompilation.
Highlighted
