Unable to send body for POST method where parameter is a presence container in the yang
https://<...>/api/config/devices/device/<device>/xxxx/_operations/run
for the above POST method, when attempted to send the parameter abc as body
<input><abc/></input>
it says malformed message/Internal error in response.
The parameter abc is a presence container for the action run ->
tailf:action run {
                tailf:actionpoint run;
                input {
                    container abc {
                        presence true;
Dan.Sullivan
What version of NSO are you using?
-Dan
NCS 4.4.2.1
I think you need to use .../api/operational/... (vs .../api/config/...) e.g.
curl -H "Content-Type: application/vnd.yang.operation+xml" -v -u admin:admin -d "<any><args>show version</args></any>" http://localhost:8080/api/operational/devices/device/volvo-fw-router-ASA-firewall-esc0-1/live-status/asa-stats:exec/_operations/any
