569
Unable to view Notification in NSO
Hi Team,
I am not able to see Notifications from Device via Netconf in the below command output.
admin@ncs# show devices device Scale_1250_Abhi netconf-notifications received-notifications
% No entries found.
Please be noted that I am receiving Notifications from Device as checked-in Raw Traces logs from NSO, but not able to view in Command output.
Raw Traces output:
#666
<?xml version="1.0" encoding="UTF-8"?>
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0"><eventTime>2021-06-02T11:05:54.682129+00:00</eventTime>
<netconf-config-change xmlns='urn:ietf:params:xml:ns:yang:ietf-netconf-notifications'>
<changed-by>
<username>admin@CLI</username>
<session-id>0</session-id>
<source-host>160.160.160.160</source-host>
</changed-by>
<datastore>running</datastore>
<edit>
<target xmlns:ni="urn:ietf:params:xml:ns:yang:ietf-network-instance">/ni:network-instances/ni:network-instance[ni:name='MY_VRF_01']</target>
<operation>merge</operation>
</edit>
</netconf-config-change>
</notification>
Abhinav R
1 REPLY 1
alexstev
