Use of ConfD REST API interface for non-configuration purpose
mahajain
ConfD provide REST API interface which can be used for configuration of device. This interface also refer to device Yang model.
Can same interface be used for non configuration activity e.g. fetching device metrics ?
alam.bilal
A device-model can have not only the configuration data but also operational data.
So if there are metrics/operational-data modeled/exposed via its device's YANG model then it can be retrieved by any of the APIs.
The URL for the operational data where the GET is done might be slightly different to that of the configuration data. Example on NSO using RESTCONF:
http://localhost:8080/restconf/data
vs
http://localhost:8080/restconf/operations
alam.bilal
vs
Thanks Bilal.
