warning: illegal character after \
macauley
Beginner
Beginner
This has to do with ncsc compile errors characters in “pattern” statements in the YANG modules.  I am encountering this issue under NSO 5.7.1.1.  Here is an example error message:
Warning: yang/coriant-common@2021-01-20.yang:237:29: warning: illegal character after \
This is related to the pattern statement `pattern "[A-Za-z0-9_\-/,\.]*";` which passes YANG regex and W3G validation in the following tool https://yangcatalog.org/yangre.
  grouping "user-defined-alias" {
    leaf "alias-name" {
      type "string" {
        length "0..256";
      description
        "User defined alias for this entity. Must be an alphanumeric string with dash or underscore";
It looks like the escaped character “\-“ is not liked by the ncsc complier.  Here is a list of all the patterns that failed compiling of the YANG.  These all pass regex validation but are generating ncsc compiler errors.
pattern "(((80|[1-7][0-9]|[1-9])(\.\.(80|[1-7][0-9]|[1-9]))?)(,((80|[1-7][0-9]|[1-9])(\.\.(80|[1-7][0-9]|[1-9]))?))*)?”;
pattern "((([a-zA-Z0-9_]([a-zA-Z0-9\-_]){0,61})?[a-zA-Z0-9]\.)*([a-zA-Z0-9_]([a-zA-Z0-9\-_]){0,61})?[a-zA-Z0-9]\.?)|\.";
pattern "((:|[0-9a-fA-F]{0,4}):)([0-9a-fA-F]{0,4}:){0,5}((([0-9a-fA-F]{0,4}:)?(:|[0-9a-fA-F]{0,4}))|(((25[0-5]|2[0-4][0-9]|[01]?[0-9]?[0-9])\.){3}(25[0-5]|2[0-4][0-9]|[01]?[0-9]?[0-9])));
pattern "((:|[0-9a-fA-F]{0,4}):)([0-9a-fA-F]{0,4}:){0,5}((([0-9a-fA-F]{0,4}:)?(:|[0-9a-fA-F]{0,4}))|(((25[0-5]|2[0-4][0-9]|[01]?[0-9]?[0-9])\.){3}(25[0-5]|2[0-4][0-9]|[01]?[0-9]?[0-9])))(%[\p{N}\p{L}]+)?";
pattern "(([0-1](\.[1-3]?[0-9]))|(2\.(0|([1-9]\d*))))(\.(0|([1-9]\d*)))*";
pattern "(([0-9]+(\.\.[0-9]+)?)(,([0-9]+(\.\.[0-9]+)?))*)?";
pattern "(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])
pattern "(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])";
pattern "(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])(%[\p{N}\p{L}]+)?";
pattern "(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5]):(6[0-5][0-5][0-3][0-5]|[1-5][0-9]{4}|[1-9][0-9]{1,4}|[0-9])";
pattern "(([A-Za-z0-9_\-][A-Za-z0-9_\-\+]*)|(\+loc:([A-Za-z0-9]{1,})\+rmt:([A-Za-z0-9]{1,})))?";
pattern "(([^:]+:){6}(([^:]+:[^:]+)|(.*\..*)))|((([^:]+:)*[^:]+)?::(([^:]+:)*[^:]+)?)(
pattern "(([^:]+:){6}(([^:]+:[^:]+)|(.*\..*)))|((([^:]+:)*[^:]+)?::(([^:]+:)*[^:]+)?)(%.+)?";
pattern "((ftp|sftp|ftps|scp|http):
pattern "(\d{2}
pattern "(\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}(\.\d+)?(Z|[\+\-]\d{2}:\d{2}))?";
pattern "(\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}(\.\d+)?(Z|[\+\-]\d{2}:\d{2}))|(all)";
pattern ".|..|[^xX].*|.[^mM].*|..[^lL].*";
pattern "[!-~\s]*";
pattern "[0-9\.]*";
pattern "[0-9a-fA-F:\.]*";
pattern "[A-Za-z0-9][a-zA-Z0-9\-_
pattern "[A-Za-z0-9][a-zA-Z0-9\-_:\.
pattern "[A-Za-z0-9][a-zA-Z0-9\-_:\.]*";
pattern "[A-Za-z0-9_\-\.]*";
pattern "[^\*].*";
pattern "[a-zA-Z_][a-zA-Z0-9\-_.]*";
pattern "[a-z_.][a-z0-9_\-.]*[$]?";
pattern "\*";
pattern "\d*(\.\d*){1,127}";
pattern "\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}(\.\d+)?(Z|[\+\-]\d{2}:\d{2})";
pattern "route\-origin:(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5]):(6[0-5][0-5][0-3][0-5]|[1-5][0-9]{4}|[1-9][0-9]{1,4}|[0-9])";
pattern "route\-origin:(6[0-5][0-5][0-3][0-5]|[1-5][0-9]{4}|[1-9][0-9]{1,4}|[0-9]):(4[0-2][0-9][0-4][0-9][0-6][0-7][0-2][0-9][0-6]|[1-3][0-9]{9}|[1-9]([0-9]{1,7})?[0-9]|[1-9])";
pattern "route\-target:(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5]):(6[0-5][0-5][0-3][0-5]|[1-5][0-9]{4}|[1-9][0-9]{1,4}|[0-9])";
pattern "route\-target:(6[0-5][0-5][0-3][0-5]|[1-5][0-9]{4}|[1-9][0-9]{1,4}|[0-9]):(4[0-2][0-9][0-4][0-9][0-6][0-7][0-2][0-9][0-6]|[1-3][0-9]{9}|[1-9]([0-9]{1,7})?[0-9]|[1-9])";
Can anyone explain why these pass YANG regex validation but fail ncsc compile?
Thank you.
cealves
TLDR: You should use single quoted strings if you want to use escaping characters.
ex:
leaf alias-name {
    type string {
        length '0..256';
        pattern '[A-Za-z0-9_\-/,\.]*';
Explanation:
On RFC6020 under the quoting section you can read:
  A single-quoted string (enclosed within ' ') preserves each character
   within the quotes.  A single quote character cannot occur in a
   single-quoted string, even when preceded by a backslash.
   Within a double-quoted string (enclosed within " "), a backslash
   character introduces a special character, which depends on the
   character that immediately follows the backslash:
    \n      new line
    \t      a tab character
    \"      a double quote
    \\      a single backslash
So since you're using double quotes and adding a backslash, yang thinks that you're introducing a special character, but you're not, your backslash is actually an escaping character for the regex.
So, to avoid this kind of issues I would recommend you to use single quoted strings on your patterns, such as the ietf draft rfc6087bis recommends:
A single quoted string SHOULD be used to specify the
   pattern, since a double-quoted string can modify the content.
 Hope it's clear.
César Alves
Thank you.  That fixed my issue.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
Recognize Your Peers
