YANG enum constraints
Hi all,
A quick YANG question; Consider a list of sites. These sites can be one of three types; hub, branch or transit. Only one hub can exist, but multiple branches and transits are allowed. How would I create this constraint within my YANG model?
list sites {
  key site-id;
  leaf site-id {
    mandatory true;
    type uint16;
  leaf site-type {
    type enumeration {
      enum hub;
      enum transit;
      enum branch;
2 Accepted Solutions
vleijon
You use a must expression. So it looks something like
  must "count(/sites[site-type='hub']) < 2";
Apparent I had an issue with the path. Solved it by using this syntax instead:
must "count(current()/../../sites[site-type='hub']) < 2"
The sites were in a list of WANs, but the path {/wan/sites[site-type]} didn't work for me either. Probably since I would have to reference the key of the WAN list (name). I dunno, but the above works.. :)
vleijon
I get this error;
warning: The 'must' expression will fail: the node 'sites' from module 'wan' (in node 'site-type' in module 'wan' from 'wan') is not found.
I've added this to the module;
list sites {
  key site-id;
  leaf site-id {
    mandatory true;
    type uint16;
  leaf site-type {
    type enumeration {
      enum hub;
      enum transit;
      enum branch;
    must "count(/sites[site-type='hub']) < 2" {
     error-message "Only one HUB can be present";
