Yang modelling error - pyang
Andre Castro
Dear friends,
I'm a beginner on NSO services modelling and running into an issue while trying to run pyang against a yang file - described in one of the NSO lab guides.
NSO version is 5.1
Pyang 1.5, but also tried 1.7.8 and 2.1. Got the same errors though.
module vlan {
  namespace "http://com/example/vlan";
  prefix vlan;
  import ietf-inet-types {
    prefix inet;
  import tailf-ncs {
    prefix ncs;
  import tailf-common{
	prefix tailf;
  description
	"Description...";
	revision 2019-11-05 {
		description
		"Initial revision";
	augment /ncs:services{
		  list vlan {
			tailf:info "VLAN Service";
			key name;
			unique vlan-id;
			uses ncs:service-data;
			ncs:servicepoint "vlan";
			leaf name {
			  tailf:info "Service Instance Name";
			  type string;
			leaf vlan-id{
				tailf:info "Unique VLAN ID";
				type uint32{
					range "1..4096";
			list device{
				tailf:info "L3 switch";
				key name;
				leaf name{
					tailf:info "Device name";
					type leafref{
						path "/ncs:devices/ncs:device/ncs:name";
			list interface{
				tailf:info "Ethernet interface";
				key "intf-type intf-id";
				leaf intf-type{
					tailf:info "Ethernet interface type";
					type enumeration{
						enum Ethernet;
						enum FastEthernet;
						enum GigabitEthernet;
				leaf intf-id{
					tailf:info "Ethernet interface ID";
					type string;
Errors:
user@mypc:~/ncs-run/packages$ pyang vlan/src/yang/vlan.yang
vlan/src/yang/vlan.yang:5: warning: imported module ietf-inet-types not used
/home/user/nso/src/ncs/yang/ietf-yang-schema-mount.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/ietf-yang-schema-mount.yang:9: error: unexpected keyword "reference"
/home/user/nso/src/ncs/yang/ietf-yang-schema-mount.yang:15: error: unexpected keyword "reference"
/home/user/nso/src/ncs/yang/tailf-ncs-cluster.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-common.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-compliance.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-customers.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-devices.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-devices.yang:3707: error: XPath function "derived-from-or-self" is not defined in the XPath context
/home/user/nso/src/ncs/yang/tailf-ncs-devices.yang:3907: error: XPath function "derived-from-or-self" is not defined in the XPath context
/home/user/nso/src/ncs/yang/tailf-ncs-java-vm.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-log.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-packages.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-plan.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-python-vm.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-service-progress-monitoring.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-services.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-smart-license.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-snmp-notification-receiver.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-software.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs-ssh.yang:2: error: bad value "1.1" (should be version)
/home/user/nso/src/ncs/yang/tailf-ncs.yang:2: error: bad value "1.1" (should be version)
Any insights will be much appreciated.
Thank you
Andre
gmuloche
in theory starting release 1.7 pyang should support YANG 1.1 and so this should not be an issue (essentially this error comes from being check against the re_version regex: https://github.com/mbj4668/pyang/blob/b7264db134929809c9749aed700f187ee4973482/pyang/syntax.py#L112
However what could be happening is the following: when you source ncsrc then it inserts pyang version 1.5 in your path (look at `which pyang`) and it won't necessary use the version you have installed on your system but the version that is shipped with NSO.
user@/tmp$ which pyang
/usr/local/bin/pyang
user@/tmp$ pyang --version
user@/tmp$ source /var/nso-5.2.1/ncsrc
/var/nso-5.2.1/bin/pyang
pyang 1.5
In theory the error reported for yang 1.1 models should not be there in pyang >= 1.7 - regarding why pyang is not changed in newer NSO version have a look at this: https://www.tail-f.com/alternatives-to-pyang-tool/
Eventually gave up from version 5.1.. Tried to work back with version 4.7 and worked as expected..
Please try under commands on NSO 5.1 version
yanger [yangfilename].yang
NSO uses yanger to validate yang file for latest nso versions.
pyang is deprecated.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
