yang type for interface ip address with mask
rainnomm56
What is the correct data type inside yang for interface ip address with mask? Like Juniper or Alcatel uses on interface 192.168.0.1/24. I like that format most, because it is most condensed.
I tried to use "type inet:ipv4-prefix" but that applies only to network addresses, not host addresses.
alam.bilal
If you are after a predefined YANG model, then you could try this one:
[nso/src/ncs/yang/tailf-common.yang]
  type tailf:ip-address-and-prefix-length;
  typedef ip-address-and-prefix-length {
    type union {
      type tailf:ipv4-address-and-prefix-length;
      type tailf:ipv6-address-and-prefix-length;
  typedef ipv4-address-and-prefix-length {
    type string {
      pattern
        '(([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])\.){3}'
      +  '([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])'
      + '/(([0-9])|([1-2][0-9])|(3[0-2]))';
    description
      "The ipv4-address-and-prefix-length type represents a combination
      of an IPv4 address and a prefix length. The prefix length is given
      by the number following the slash character and must be less than
      or equal to 32.";
alam.bilal
    type union {
    type string {
      pattern
    description
      or equal to 32.";
