Hello,It's my first time installing nso on my mac m1 laptop. I did it via local install and ncs_cli -u admin works fine. I can do "?" and see many commands that I have access to. After searching for hours on how to solve this, it seemed like I need t...
view more
The NSO Config Monitor is targeted to discover and report unmanaged device configurationsas well as configuration changes that were introduced outside of NSO. It is designed to work as plug-in package named config-monitor, which can be installed and used&...
view more
Getting the below error while upgrading from lower version to higher version.
admin@ncs# configEntering configuration mode terminaladmin@ncs(config)# devices migrate old-ned-id cisco-staros-cli-5.37 new-ned-id cisco-staros-cli-5.40migrate-result {d...
view more
Hi. We have a 5.8.1 CFN configured with two RFNs, one with 5.8.1 and the other with 4.7.11 (this one will have to stay on this version for a while because of... reasons). CFN has cisco-nso-nc-4.7 and cisco-nso-nc-5.8 packages added and reloaded, RFNs...
view more
