Create a device using REST
1430
Create the Device
curl -H "Content-Type:application/vnd.yang.data+xml" -X PUT -u admin:admin -d @ios3.xml http://localhost:8080/api/running/devices/device/ios3
Fetch SSH Keys
curl -H "Content-Type:application/vnd.yang.data+xml" -X POST -u admin:admin http://localhost:8080/api/running/devices/device/ios3/ssh/_operations/fetch-host-keys
Sync From
curl -H "Content-Type:application/vnd.yang.data+xml" -X POST -u admin:admin http://localhost:8080/api/running/devices/device/ios3/_operations/sync-from
ios3.xml
<device xmlns="http://tail-f.com/ns/ncs">
  <name>ios3</name>
  <address>127.0.0.1</address>
  <port>10022</port>
  <state>
    <admin-state>unlocked</admin-state>
  </state>
  <authgroup>default</authgroup>
  <device-type>
    <cli>
   <ned-id xmlns:ios-id="urn:ios-id">ios-id:cisco-ios</ned-id>
    </cli>
  </device-type>
</device
Beginner
Outstanding!
  Thank you so much!!
A little bit late on this thread but I have issue using the processes described above for an IOS-XR devices
I am using NSO 4.5.1 with the latest ios-xr package installed
cisco@ncs# show packages package package-version
          PACKAGE
NAME VERSION
cisco-iosxr 6.3.2
cisco-pnp 1.10.0
pioneer 2.24.0
spine1 1.0
curl -H "Content-Type:application/vnd.yang.data+xml" -X PUT -u admin:admin -d @ios-xr1.xml http://localhost:8080/api/running/devices/device/ios-xr1
ios-xr1.xml
  <name>ios-xr1</name>
  <address>172.30.13.8</address>
  <port>22</port>
  <state>
  </state>
  <authgroup>dev-FOC21074JRT</authgroup>
  <device-type>
  <cli>
   <ned-id xmlns:ios-id="urn:ios-id">ios-id:cisco-ios-xr</ned-id>
    </cli>
  </device-type>
</device>
Error
cisco@nso-server:~/NSO/rest$ ./create-dev.sh
<errors xmlns="http://tail-f.com/ns/tailf-rest-error">
  <error>
    <error-tag>malformed-message</error-tag>
    <error-urlpath>/api/running/devices/device/ios-xr1</error-urlpath>
    <error-message>invalid value for: ned-id in /ncs:devices/ncs:device[ncs:name='ios-xr1']/ncs:device-type/ncs:cli/ncs:ned-id: "ios-id:cisco-ios-xr" is not a valid value.</error-message>
  </error>
</errors>
Same error is I change the ned-id from cisco-ios-xr to cisco-ios
creating the device with the ned-id cisco-ios-xr by hand works perfectly
Easiest to get I right is using the CLI and an existing device:
Show device device foo device-type | display xml
That should give you something to cut and paste.
//F
Sent from my iPhone
Agree with Fredrik,
With a new NED, ned-id should be:
admin> show configuration devices device pe1 device-type  | display xml
<config xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
  <device>
    <name>pe1</name>
      <device-type>
        <cli>
          <ned-id xmlns:cisco-ios-xr-id="http://tail-f.com/ned/cisco-ios-xr-id">cisco-ios-xr-id:cisco-ios-xr</ned-id>
        </cli>
      </device-type>
  </device>
  </devices>
</config>
[ok][2018-01-05 09:02:40]
admin>
Roque
Thank you guys I did not know you could output the command in XML, it works now ! For future reference here is the correct XML file for my example
  <port>22</port>
  <state>
   </state>
   <device-type>
     <cli>
     </cli>
   </device-type>
</device>
Trying to do the same thing with JSON instead but getting 400/405 errors:
{"errors": {"error": [{"error-message": "post to a nonexistent list resource", "error-urlpath": "/api/config/devices/device/ucsm011/config/ucs:org/service-profile/test", "error-tag": "malformed-message"}]}}
curl -X POST -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/org/service-profile -d @innopodtest.json
{"errors": {"error": [{"error-message": "POST on list must be on list element", "error-urlpath": "/api/config/devices/device/ucsm011/config/ucs:org/service-profile", "error-tag": "malformed-message"}]}}
Not sure which is the correct path here nor the correct data schema.  Pulled the config with the following:
curl -s -X GET -u nsouser:nsouser -H "Accept: application/vnd.yang.data+json" "http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/org/?deep" > ucsm011.yaml 2>&1
and here are the first few lines followed by the snipped i am trying to use to configure.
[start...]
   "tailf-ned-cisco-ucs:org": {
     "service-profile": [
[...end]
    "boot-policy": "pxe",
    "identity": {
        "dynamic-uuid": "00000000-0000-0000-1111-111111111110"
    "local-disk-policy": "disk-policy",
    "name": "nsotest",
    "vcon-assign": {
        "ethernet": {
            "fc2": [
                    "admin-vcon": "any",
                    "host-port": "any",
                    "order": 1,
                    "vnic-vhba": "eth0"
    "vnic": [
            "eth-if": [
                    "name": "default"
                    "default-net": "yes",
                    "name": "somevlan"
            "identity": {
                "dynamic-mac": "00:25:B5:E9:12:00"
            "name": "eth0",
            "order": 1
Any difference if you use PUT?
I tried this with the IOS NED:
curl -u admin:admin -X PUT -H "Content-Type: application/vnd.yang.data+json" -d @arp.json http://localhost:8080/api/running/devices/device/volvo-fw-router-CSR1kv-CSR-esc0-1/config/ios:ip/gratuitous-arps-conf
arp.json:
  "tailf-ned-cisco-ios:gratuitous-arps-conf": {
    "gratuitous-arps": true
Sorry, I mean to mention I tried PUT as well.
SECHANDL-M-41AW:NSO sechandl$ curl -X PUT -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/ucs:org/service-profile/nsotest -d @innopodtest.json
{"errors": {"error": [{"error-message": "syntax error", "error-urlpath": "/api/config/devices/device/ucsm011/config/ucs:org/service-profile/nsotest", "error-tag": "malformed-message"}]}}
SECHANDL-M-41AW:NSO sechandl$ curl -X PUT -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/ucs:org/service-profile -d @innopodtest.json
SECHANDL-M-41AW:NSO sechandl$ curl -X PUT -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/ucs:org -d @innopodtest.json
{"errors": {"error": [{"error-message": "syntax error", "error-urlpath": "/api/config/devices/device/ucsm011/config/ucs:org", "error-tag": "malformed-message"}]}}
The service-profile element in UCS org is a list.  Not sure if different semantics exist for lists?
-s
A bit, you PUT/POST to base-url/<key>, another example:
http://localhost:8080/api/running/nfvo/ns-info/esc/ns-info/MyNSInfo
  "tailf-etsi-rel2-nfvo-esc:ns-info": {
    "id": "MyNSInfo",
    "tenant": "volvo",
Errors about non-existent list resource as well which seems like a clue.
SECHANDL-M-41AW:NSO sechandl$ curl -X POST -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/org/service-profile -d @innopodtest.json
SECHANDL-M-41AW:NSO sechandl$ curl -X POST -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/org/service-profile/nsotest -d @innopodtest.json
{"errors": {"error": [{"error-message": "post to a nonexistent list resource", "error-urlpath": "/api/config/devices/device/ucsm011/config/ucs:org/service-profile/nsotest", "error-tag": "malformed-message"}]}}
SECHANDL-M-41AW:NSO sechandl$ curl -X PUT -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/config/devices/device/ucsm011/config/org/service-profile/nsotest -d @innopodtest.json
    "identity": {
    "name": "nsotest",
    "vcon-assign": {
        "ethernet": {
            "fc2": [
                    "host-port": "any",
                    "order": 1,
                    "vnic-vhba": "eth0"
    "vnic": [
            "eth-if": [
                    "name": "default"
                    "name": "somevlan"
            "identity": {
            "name": "eth0",
            "order": 1
I think I see it, you have the wrong URL, should be /api/running/..., you have /api/config/...
Thanks!
After the URL fix I just had to fiddle with the content of the JSON and now it is working with the following:
curl -X PUT -u nsouser:nsouser -H "Content-Type: application/vnd.yang.data+json" http://127.0.0.1:8080/api/running/devices/device/ucsm011/config/ucs:org/service-profile/nsotest -d @innopodtest.json
{ "service-profile": [
    "identity": {
    "name": "nsotest",
    "vcon-assign": {
        "ethernet": {
            "fc2": [
                    "host-port": "any",
                    "order": 1,
                    "vnic-vhba": "eth0"
    "vnic": [
            "eth-if": [
                    "name": "default"
                    "name": "somevlan"
            "identity": {
            "name": "eth0",
            "order": 1
Awesome!!
