You can finally access both slides and recordings from the hybrid event. All links below are sorted according to the Stockholm agenda. Note that there were two sessions exclusive to the virtual event that you don't want to miss.
Agenda
Day 1
view more
Hi DevNet Folks, If you are studying for any DevNet certs (specifically SPAUTO or DevNet Expert) which expects you to work with Cisco NSO and you want to find an easy way to get started with NSO, I have created a following repo, where you find two im...
view more
Hi, We have a instance of NSO community edition running in our lab. We wanted to try performing OS/firmware upgrade on Cisco routers/switch using NSO. It is learnt that os upgrade service package needs to be installed.Is it possible to install the os...
view more
Hi everyone,I have tried some RESTCONF requests on a Catalyst 9300 with IOS XE 17.3.1, all the responses have the ETag header except the GET. For what reason? Thank you,Daniele
