Dates are now set for the next Developer Days in US! The exact location and form for the event are still in the works. If possible this may very well be the first hybrid event for us in a long while.
I am attempting to use the documented for loop in an xml template and am getting an error that says: Invalid parameters or processing instruction for This is the section where I am using the loop: <interface xmlns="http://tail-f.com/ned/...
view more
Hello,I am trying to construct the curl call to push a device config onto an existing device on NSO. Similar to this: https://community.cisco.com/t5/nso-developer-hub-discussions/rest-api-for-config-push-onto-nso-device/m-p/3604043#M2330 bu...
view more
