NSO 4.4.1 is now available.
Customers can download the new version from Download Software - Cisco Systems .
The release is available from the Software Jive Sub-space if you are an NSO ATP partner.
Customers are recommended to upgrade to the latest NSO release at least annually, in order to take advantage of the latest features, and to remain on a supported version, as well as benefiting from the latest security updates.
The End-of-Life (EOL) policy is available at http://www.cisco.com/c/en/us/products/eos-eol-policy.html. Cisco NSO EOL notifications are at http://www.cisco.com/c/en/us/products/cloud-systems-management/network-services-orchestrator/eos-eol-notice-listing.html
Removals:
- Web UI: Deprecated the NSO status view
(Issue tracker: #25907)
Non-backwards compatible enhancements:
- ncs: Non-backwards compatible correction:
Web Server: Cipher suites using RC4 are no longer supported for the
SSL/TLS server, since this algorithm is not considered secure.
Enhancements:
- ncs: NSO is now integrated with Cisco Smart Licensing.
- ncs: The Nano Services experimental feature have been introduced as a
new way of executing/controlling Reactive FASTMAP services.
See the Nano Services chapter in the Development Guide for more
information on this.
- ncs: The speed of the sync-from operation for CLI NEDs has been
improved. Improvements are mainly for large configurations and has been
measured to range from reducing the execution time by half to a fourth
but the improvement varies greatly between different NEDs and
configurations.
- ncs: It is now possible to write directly into target transaction in
CLI NED's show() callback in addition to returning the commands via
worker.showCliResponse() call. The transaction ID can be accessed with
worker.getToTransactionId().
- ncs: When committing through the commit-queue on the top-node in a LSA
cluster, this will now propagate to commit-queue commits on the
lsa-nodes as well. This implies that top-node commit-queue queue-item
will not finish before all related lsa-node commit-queue items has also
finished.
- ncs: A new device is now copied to the snapshot database when
/ncs-config/cdb/snapshot/pre-populate = true.
- ncs: Implemented 'partial-sync-from' action which allows to synchronize
parts of the device's configuration by pulling from the network.
(Issue tracker: #27878)
- CLI: The yang extension tailf:default-ref has been ported to NSO. It is
currently limited to relative paths and absolute paths will be ignored.
- CLI: The southbound interfaces of the CLI are now started already in
phase1. The northbound interfaces start in phase2 as before.
(Issue tracker: #26023)
- CLI: Increased performance during user interaction with the CLI.
(Issue tracker: #27069)
- Python API: Removed the undocumented limitation of only supporting
implementation of validation callbacks in one Daemon per Python VM
(Issue tracker: #26451)
- Smart Licensing: An internal notification kicker that keeps track of
licensing entitlements sent from sub components, such as ESC, was
added. NSO aggregates the licensing entitlements and reports to the
Cisco smart licensing cloud.
Corrections:
- ncs: Previously, set-hooks weren't invoked for uncommitted nodes if
they were deleted as a result of parent node deletion. Deleting the
node with the set-hook explicitly invoked the set-hook. The behaviour
is now consistent; regardless of why the node is deleted, set-hooks are
invoked.
(Issue tracker: #25655, #26971)
- ncs: Trying to create a mandatory empty leaf with
tailf:cli-hide-in-submode would result in an error. This has been
fixed.
(Issue tracker: #25759, #681387776)
- ncs: If a data model had a symlink to a node that was augmented by
another model, the augmented nodes would in some cases not appear under
the symlink. This bug has been fixed.
(Issue tracker: #26689)
- ncs: An un-escaped caret (`^`) was incorrectly treated as negation in a
regular expression "character group" also when it was not the first
character in the group. This has been fixed.
(Issue tracker: #26949)
- ncs: Previously NSO would get an internal error when trying to display
the /devices/device-module list without read access to do so.
(Issue tracker: #27059)
- ncs: If an rpc or action was implemented via tailf:exec, and the input
had a leaf augmented from another module into a 'choice', followed by
non-augmented nodes, the invocation of the executable would fail. This
has been fixed.
(Issue tracker: #27138)
- ncs: When redeploying a package the Python code (if any) contained in
that package was not updated. This has been fixed.
(Issue tracker: #27144)
- ncs: When applying a 'device template', i.e the apply-template action
on a device, from a service, the backpointers and ref-counters was not
updated properly. This has been fixed.
- ncs: Previously paths passed to the showPartial call in the CLI NED
ignored leafs with hide-in-submode annotation. This has now been fixed.
- ncs: If a YANG union (other than inet:ip-address) had both
inet:ipv4-address and inet:ipv6-address member types, in that order,
IPv6 addresses would be displayed with uppercase A-F instead of a-f.
(Issue tracker: #27718)
- ncs: Previously commit queue blocked alarm was not cleared when a
device reconnected or failed to reconnect. This has now been fixed.
(Issue tracker: #27724)
- ncs: Previously NSO could not read leaf-lists correctly in NETCONF
notifications. This has now been fixed.
- ncs: The YANG extension tailf:ned-ignore-compare-config excludes this
model elements from comparison in e.g. /devices/device compare-config.
This will also be excluded in device data comparison in a commit
no-overwrite.
- ncs: out-of-sync-behaviour = accept did not always suppress
get-trans-id on the NED. This has been fixed.
- C-API: String <-> value conversion for the type inet:ipv6-prefix could
fail incorrectly in the C and Python APIs if the prefix length was not
a multiple of 4. This has been fixed.
(Issue tracker: #27184)
- CLI: There is inconsistent behavior when it comes to the tailf:info
string with backslash. Display of '{{{\\}}}n' is rendered as '\n' or
'n' in different possible completions in the CLI output. This has now
been fixed by rendering them all to '\n'. So in order to display one
backslash character in the tailf:info output, it needs to define either
'{{{\\}}}' (single quoted string) or "{{{\\\\}}}" (double quoted
string) for the tailf:info in the yang file.
(Issue tracker: #12142)
- CLI: Creating a list instance containing a unique statement referring
to one of the keys, would in some cases not be reflected when
displaying the C-style configuration diff (i.e. 'commit dry-run
outformat native'). This has been fixed.
(Issue tracker: #24811)
- CLI: Command "show running-config | extended" returns internal error.
(Issue tracker: #26688)
- CLI: When NSO sync-from a NED device which has unmodeled config that
CLI fails to parse, the resulting syntax error entries are shown as
info in the trace log.
- CLI: Enforce "repeat" command to always suppress pagination.
(Issue tracker: #27047)
- CLI: Validation of leaf_list data nodes in the CLI has been added when
processing parameters to actions.
(Issue tracker: #27182)
- CLI: Backslash character is always ignored in tailf:info output. This
has now been fixed. So in order to display one backslash character in
the tailf:info output, it needs to define either '{{{\\}}}' (single
quoted string) or "{{{\\\\}}}" (double quoted string) for the
(Issue tracker: #27301)
- CLI: The combination of using the extensions
tailf:cli-sequence-commands and tailf:cli-incomplete-no would break the
functionality of tailf:cli-incomplete-no extension. This has now been
fixed.
(Issue tracker: #27311)
- CLI: TAB completion on enum with tailf:info terminates CLI connection
abnormally. This has now been fixed.
(Issue tracker: #27725)
- Documentation: Support of following Browsers are deprecated:
Safari older than 10.0
Internet Explorer older than 11
Firefox older than 45
Chrome 50 and older
- JSON-RPC: The method 'get_schema' couldn't handle a node with multiple
when statements (through tailf:annotate). This has been fixed.
(Issue tracker: #27518)
- NETCONF: A leaf of type empty augmented from another module into the
'input' of an rpc caused a northbound NETCONF session to terminate, and
the same for an action was delivered to the callback as an empty
container (i.e. with begin/end tags). These bugs have been fixed.
(Issue tracker: #27057, #27068)
- NETCONF: Invocation of an rpc or action where 'input' had a 'choice'
child, and the first 'case' of that 'choice' was another 'choice',
caused a northbound NETCONF session to terminate. This has been fixed.
(Issue tracker: #27058)
- Python API: The implementation of events.NOTIF_COMMIT_DIFF was broken.
It was impossible use the contained tctx to attach to the current
transaction. This has been fixed.
(Issue tracker: #26992)
- Python API: When an action- or service-callback timed out the
connection to NSO was lost and the only way to restore the connection
was to reload the affected package. This has been fixed, so now the
Python-APIs data provider implementation automatically reconnects to
NSO.
(Issue tracker: #27012)
- Python API: When enabling IPC access check in ncs.conf packages written
in Python didn't work. This has been fixed.
(Issue tracker: #27279)
- Python API: When a python service is changed or re-deployed the back
pointer and reference counter was lost. This has now been corrected.
To correct this for already instantiated python services do:
request /path-to-python-service * re-deploy
If the '*' is not accepted as input the service YANG file needs to be
updated by importing the tailf-common module:
import tailf-common {
prefix tailf; }
and add the tailf:cli-allow-range annotation to the key leaf node of
the service.
- Python API: Some of Maagic's components failed to check for an existing
MAAPI backend when used as input and output parameters for an Action.
In some cases this lead to a raised Exception. This has been fixed.
- Python API: Running NSO with a Python package using Python 3 failed
with "AttributeError: module '_ncs' has no attribute
"internal_connect". This has been fixed.
- REST API: REST Query API fetch-query-result calls don't timeout after
five seconds anymore, instead it adheres to the default timeout of 600
seconds (10 minutes). Added timeout parameter to start-query and
reset-query enabling a custom timeout.
(Issue tracker: #26893)
- REST API: An empty rollback file caused the REST(CONF) API to stop
working. This has been fixed.
(Issue tracker: #27520)
- RESTCONF: If an action error response is customized by using
confd_action_seterr_extended(), the error is now propagated by
RESTCONF. Previously RESTCONF always responded with a HTTP 400 and
error-tag "operation-failed".
(Issue tracker: #27860, #27917)
- RESTCONF: In some cases RESTCONF erroneously used the mediatypes
text/xml and text/json. They have been replaced with the correct
application/yang-data+xml and application/yang-data+json respectively.
- Smart Licensing: When a 'packages reload' was issued, smart licensing
failed to report NED packages correctly. This has been fixed.
(Issue tracker: #24559)
- SNMP Agent: When compiling yang modules augmenting other yang modules,
the effective snmp-mib-module-name of any augment node was
unconditionally inherited from the augment target node. This lead to
MIB modules with no objects corresponding to the augment nodes, if the
resulting fxs file was used with ncsc --emit-mib. This has been fixed,
so that snmp-mib-module-name is only inherited if the current module
doesn't have a snmp-mib-module-name statement.
(Issue tracker: #25677)
- Toolchain: When there was a chain of identities defined in a YANG
module like a <- b <- c, the ncsc would sometimes not accept all
derived identities in the "default" statement. This bug has been
fixed.
- Web UI: List of supported browser now only exists in the installation
guide.
- Web UI: Lists on root level now works correctly.
(Issue tracker: #26063, #26546)
- Web UI: Leafref widgets now filteres items by regex.
(Issue tracker: #26710)
- Web UI: The leaf-list widget now handles special characters correctly.
(Issue tracker: #27094)
NSO-4.4.0.2 [April 26, 2017]
Corrections:
- cluster:Â When-expressions in remote devices have been incorrectly
evaluated on service node in cluster. This has been fixed.
(Issue tracker: #27947)
- ncs: When using 'commit no-overwrite' to commit a transaction towards a
NETCONF device (or an lsa node), and that transaction contained changes
to multiple list instances - the filter used to fetch the modified list
instances would not be correctly built - resulting in an RPC error when
trying to commit. This has been fixed.
(Issue tracker: #27881)
- Smart licensing: The Smart licensing high availability adaption could
cause node crashes due to out of memory when switching a node from slave
to master. This has been fixed.
(Issue tracker: #27799)
NSO-4.4.0.1 [April 25, 2017]
Corrections:
- CLI: Un-deploying a service would in some cases cause the CLI to hang until
host ran out of memory. This has been fixed.
(Issue tracker: #27711)
- ncs: Previously un-deploy dry-run did not actually show what the un-deploy
action would do but rather like 'get-modifications reverse'. This has now
been fixed.
(Issue tracker: #27745)
